stock radio wire question inside...
Old May 12, 2005 | 10:45 PM
RICHRAD's Avatar
factory cd player pics inside and prior wiring ?
The brown and orange wire off to the back side of my factory deck, so what does the brown one do? I know the orange is constant power . I'm installing a cd player out of a 95 bonnie, so I'm splicing the factory cd harness to an 88 and older adapter. Therefore I won't have to cut my factory harness. On the cd harness there are two brown's. One was for a speaker, but I'm unsure as to the other . Don't want to fry anything. thanks for any help!
Old May 23, 2005 | 09:22 PM
RICHRAD's Avatar
well anyways...Did the install without the brown wire hook-up.
Old May 23, 2005 | 09:26 PM
RICHRAD's Avatar
here's another pic ..I got an extra '95up cd player wiring harness if anyone's interested... This unit plays cd great !
Old May 24, 2005 | 12:03 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
ya its prolly something useless. I know the dimmer is back there somewhere which is useless cuz I dont think any radios actually use that feature. Or have yet to see one.
Old May 24, 2005 | 04:46 PM
RICHRAD's Avatar
Yeah was thinking it was for the display day/night dim. But now that my performance bass **** on dash is not working , begining to think that either that brown one or the one that says antenae should be connected somewhere..
Old May 25, 2005 | 11:41 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Looks good! Love the 'Performance Sound' emblem you grabbed too!
How's it sound? Are you running stock speakers?
Old May 25, 2005 | 04:30 PM
RICHRAD's Avatar
The emblem is stock for my car. Notice the boost slide switch above it. I have factory subwoofers stock and it rocks
Old May 25, 2005 | 04:45 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Oh yah, I didn't see the slider. I never knew the Firebirds got that emblem too though, as I found mine in a Bonneville.
Old May 26, 2005 | 11:30 PM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
stereo wires
(thanks to kanuck from knight registries for this one.)
This is general for GM vehicles from 1971-2000. Might not be perfect, but it worked really well in my 82 T/A.
Yel - +12V
Pnk - Power Antenna
Blk - Ground
Gry - Illumination (of the light in the stock stereo)
Dk. Grn - Right Front -
Gry - Left Front -
Lt. Grn - Right Front +
Tan - Left Front +
Yel - Left Rear -
Lt. Blu - Right Rear -
Brn - Left Rear +
Dk. Blue - Right Rear +
Orn - Memory
Brn - Dimmer
Old May 27, 2005 | 03:23 PM
RICHRAD's Avatar
But why did my Bass boost slide stop working when I installed the cd player...anyone? Not sure how that thing wires up.
Old May 31, 2005 | 06:04 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Well unfortunatly i do not have the performance audio option, but in my '89 i have the wiring for it, all of our cars do. There should have been two harnesses that you had to pull from your stock radio, one big one (the one with the speaker wires) and then there should have been another one with only two wires, one orange and the other black, this wiring harness is for the amp that powers your amp for those subwoofers. Hopefully, the new stereo you put in has provisions for that harness, if not you are going to have to find some way to wire that up with the stereo's power, that stuff im not all too familiar with. If it was me i would look for the provisions on the Olds radio, it might be different but you could find a way to adapt it, like use the harness from the car you got it from and splice it with yours. Or you could just put your stock stuff back in, or you could search for an eq tape player or eq cd player radio for our cars. Hope this helps
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
ZsTransAm
Aug 11, 2015 07:30 PM
