high pitch squeel from speakers (noise filters)
Old 09-02-2005, 02:34 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
hi,
i seem to just start getting a bad wine thru my speakers while my car is running during cd play. I assume its ignition noise. I have what i bealive to be a inline noise filter sitting in a drawer at home.... when i open up the little square black box i see a transfomer.
Will putting this in my car help the wine.... What wire sould i run it "in line" with the red or yellow wire cd player wires. Also why am i getting this wine i never had it before and nothing on my car i have changed in the last while would be connected to me just now start getting a bad high pitch squeel.
Old 09-03-2005, 08:09 AM
Car: '81 Trans Am
Engine: 6.6L
anyone??
Old 09-04-2005, 02:32 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
that will help if it is a grounding problem, yes.. but not the right way to fix it.
do you get the noise when you are listening to the radio?
did you change anything that could have caused this?
were there any symptoms before this?
Old 09-04-2005, 08:12 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
it could be a crossover u have at home which just limits the frequincies the speaker will use...u can make your own noise filters though or get one from radio shack i think all it is is a wire rapped many times around something possibly a magnet but ive never needed one so not positive...id say if it started from no where check your connections then double check them (rcas, speaker wire, ground, power...etc...) then check to make sure u havent rubbed the casing around the wires off anywhere.
Old 09-04-2005, 09:54 PM
ScrapMaker's Avatar
a crossover is actually a combination of inductors and capacitors
capacitors limit the low frequencies--for tweeter use
inductors limit the high frequencies--for woofer use
for midrange, you use both at the same time...
yes you can easily make a crossover, but you need to do some math, and know some very specific information about your speakers... which is why not many do it, unless their pros...
Old 09-05-2005, 07:46 AM
Engine: 305 tbi l03
yeah i know thats what a crossover is lol i didnt word that very well i meant to make your own noise filter....but if u wanna make your own crossovers its not hard there are schematics out there everywhere w/ all kinds of diff. inducers and compacitors to play w/.
Old 09-05-2005, 11:42 AM
ScrapMaker's Avatar
It's not hard to make a ground-loop isolator, if that's what you mean by noise filter.
Essentially, it's just just a metal rod with two coils on it very close together. The first one has takes the RCA signal and converts it to magnetism, and the second coil recieves the magnetism and converts it back to electricity..
They aren't 100% efficient, and are viewed as more of a band-aid to fix a larger problem. All it does is make it so your headunit, and amplifier cannot ground themselves via the RCAs.
Old 09-06-2005, 07:36 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
jcurrieirocz, What's the make and model of the HU? Which speakers are making the noise? Are they amped? Did you cut THAT noise filter off of the harness for the HU you are using?
Old 09-15-2005, 09:45 AM
Car: '81 Trans Am
Engine: 6.6L
thanks anyhow guys i got it fixed all i did was remove my eq that wasnt hooked into anything anyhow as i need to get it repared and i taped up where the 3 sets of rca cables go into my deck and yes i was amped. I assume it was an rca problem.
Old 09-16-2005, 05:03 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Open ground on the RCAs...
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Hotrodboba400
12-10-2019 07:07 PM
GouldyGTR
09-07-2015 09:05 PM
Stryker412
09-07-2015 09:11 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: high pitch squeel from speakers (noise filters)
