What ohm is a home theatre amp?
Old Nov 19, 2005 | 03:56 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have a KLH surround sound subwoofer, with an 8" speaker in it. It sounds pretty decent, so I had a thought... I'm going to see how it sounds in my car using an inverter!
Don't tell me not to, I'm bored. This isn't permanent or anything, just sheer boredom
I was wondering though, what OHM is the amp most likely? The speaker doesn't say, nor can I find it on the amp anywhere. Someone told me that home audio uses high OHM's, like 8 or 16 or something like that.
I ask because I have many 8" subs sitting around, but I don't want to cook anything!
If my question makes no sense, feel free to e-smack me
Old Nov 19, 2005 | 04:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, usually 6 or 8.
JamesC
Old Nov 19, 2005 | 05:09 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
That's it, it was 6. Totally random. Will I hurt the speaker or amp if I put a standard car audio one in there?
Old Nov 20, 2005 | 01:08 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
depends, whats the voice coil configuration? you can wire a dual 4 ohm voice coil sub, which is pretty common in car subwoofers, to an 8 ohm load
Old Nov 20, 2005 | 02:03 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, the amp is a single vc setup, and if it's 6ohm, could I wire a dvc sub to match that?
Old Nov 20, 2005 | 04:04 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Very few companies make anything that has a d3 or a single 6 ohm coil(s). JL makes a few dual 3 ohm speakers, but those are a bit on the pricey side. They’re defiantly not worth it in the name of trying something new.
You might be ok with driving the amp with a 4 ohm load though, kind of like how you can drive some car amps past their rated limits.
Why are you so worried about breaking something anyway? The sub won’t have any more/less power going to it than it already does in your house.
Old Nov 20, 2005 | 06:17 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, the sub blew that was in it... I had it a little loud. So a single voice coil 4 ohm sub would be best suited to it?
Old Nov 20, 2005 | 08:34 PM
Gummie's Avatar
Car: 88 GTA
I didn't realize that you had blown it. This brings a plethora of questions to mind because you're trying to match the enclosure as well as the amp.
How big is the box? Is it ported/sealed? Those two things will have a hand in what sub you can choose to get more or less the same results. You're also going to want to avoid power hungry drivers (ie high output car drivers) because odds are that the amp probably isn’t that high output. You might want to poke around parts express (.com) or post on a home theater board as to where you can buy 6 ohm drivers.
As for 6 vs 4 ohms, your amp might be ok with a 4 ohm load. There’s really no way of guaranteeing it unless you call the manufacture and they probably won’t be able/willing to tell you.
Old Nov 20, 2005 | 09:04 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ahh, got ya. It's a 1cf ported box. I'm just looking for something to replace it, nothing crazy expensive or anything!
Fanatic1074
Oct 3, 2022 05:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
lewandom
Oct 1, 2015 08:15 AM
raymondandretti
Sep 27, 2015 06:43 PM
ironbmt
Sep 27, 2015 06:00 AM
