15'' sub box
Old Mar 5, 2006 | 05:53 PM
buckwhizzle's Avatar
Car: 1986 chevy IROC Z28
15'' sub box
i have a single 15'' L7 solo-baric i need to build a box for it but i dont no where to build it. im open to any sugestion
thanks
Old Mar 5, 2006 | 06:20 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Get WinISD to simulate, if you wish:
http://www.linearteam.dk/default.aspx?pageid=winisd
Also, there's a few people on here who build boxes. You can get one off of them or they may offer some tips on doing your own. I have the 12" L7s and they DO NOT like the minimum sealed box volume Kicker recommends. It's best, in my opinion, to go with a larger (~3+ cubic feet) sealed box or even better ported with that particular sub.
Old Mar 5, 2006 | 10:18 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Kicker offer excellent box plans for their subs. The 2006 manual can be found here. The Tech Brief from '04 is better for box plans, T/S parameters, and response curves, http://www.kicker.com/06/tech-suppor...ch%20Brief.pdf. Ported the 15" L7 needs at least 3 cubic feet net.
There's not a lot of room back there for a 15. The well area is only about 13.5" across front to back. Obviously, none of the Kicker designs will work in the back of an F-body, but they're a starting point. You could make the box wider at the top face to account for the speaker's diameter, but then narrow below it.
I agree WinISD is a great tool in designing a subwoofer box. Most of the Kicker models' specs are already entered into the program. Of all the L7's, the 15" is the only one I would even consider running sealed.
Old Mar 11, 2006 | 05:36 PM
thanks for the info.
i have decided to fold my back seat down and build a box on it. and face the box to the rear of my car for my 15 i dont use my back seats so why not.
Old Mar 11, 2006 | 06:02 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
That's what I do, but with two 12's instead. I'm 6'4" and it is literally a perfect fit. I still gots my legroom. I got a few feet of solid copper wire & 4 metal loops from Home Depot to secure the box in place. Whenever I braked even a little bit hard, the ~140 lb box would slam into my seat and push it forward a little -- got REALLY old really fast. I wrapped the solid wire around the rear seat latch bolts and that works great!
Old Mar 14, 2006 | 11:36 AM
woody88's Avatar
Car: 91
Engine: 3.1 v-6
i have a single 15 jl w-6 i just put a 4.3 cubic foot tuned 28hz in the back seat it works good, got it metered lst weekend at 139.7db but with it facing to the back it is going to cancel its self out but im goin to get a design for two 15's to put in the hatch if i can get it from my cousin i will post it if i get it.
Old Mar 14, 2006 | 05:02 PM
1989GTABlown632's Avatar
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
I built this with a peice of 3/4 MDF and used the trunk to seal it 2 15"s and a 10"
Old Apr 1, 2006 | 02:07 PM
[IMG]C:\Documents and Settings\Owner\Desktop\New Folder (2)[/IMG]
Old Apr 1, 2006 | 08:08 PM
15''
i got a box for my 15
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
