amp cooling problem, not like the other one
Old Apr 23, 2006 | 07:44 PM
lowgas&rubber's Avatar
Car: 97 b4c camaro
Engine: 350 lt1
I have a 6 or 7 year old jensen 200 W amp 2 ch. I dont know what ohm it is stable at but i have it bridged. It has no fans or openings, it is all solid everywhere around. It heats up fast and burnt myself on it. It also shuts off when turning it up too loud when warmed up. What way can I keep it cool or mount it where can stay cool. thanks for any advice.
Old Apr 23, 2006 | 08:10 PM
lockchad's Avatar
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
first, find out what kind of ohm load your speakers are and get back to us.
Old Apr 23, 2006 | 08:15 PM
Car: 97 b4c camaro
Engine: 350 lt1
how can I find out what ohm load its puttin out?
Old Apr 23, 2006 | 08:26 PM
lockchad's Avatar
Engine: 305 5.0L
1: pull the speaker/sub and look on the back of each one.
2: at the final set of wires connect a ohm meter or multi meter.
ohm loads on speakers are as important to a car stereo as a exhaust is on a motor.
Right amount of restriction= good. Wrong amount of restriction=bad.
Old Apr 24, 2006 | 07:15 PM
Car: 97 b4c camaro
Engine: 350 lt1
i checked it and it is a little over 4 ohms.
Old Apr 24, 2006 | 09:29 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
4 ohms per coil, 4 ohms final?
To put this simply: how many subs are you running? How many coils do they have? What’s the resistance of one coil?
If your final load is 4 ohms you should be fine assuming the amp is bridgeable to 4 ohms. I would be surprised if it's not.
Old Apr 24, 2006 | 09:31 PM
Car: 97 b4c camaro
Engine: 350 lt1
i am running 1 sub with dual voice coil
Old Apr 24, 2006 | 09:59 PM
Gummie's Avatar
Car: 88 GTA
2 ohm coils or 4 ohm coils? Just trying to make sure we're saying the same thing when you say 4 ohms
Old Apr 25, 2006 | 08:48 PM
Car: 97 b4c camaro
Engine: 350 lt1
4 ohm coils
Old Apr 25, 2006 | 09:27 PM
Gummie's Avatar
Car: 88 GTA
4 ohm coils
So your wiring choices are 2 or 8 ohms, 2 ohms being the preferable choice. Post the model # on the amp and someone will be able to turn up whether or not it's 2 ohm stable.
Old Apr 26, 2006 | 04:27 PM
lockchad's Avatar
Engine: 305 5.0L
yeah if its a jensen amp i don't think its capable of 2ohm mono bridged (aka 1ohm) operation. Hence your overheating problem.
4 and 4 parallel = 2ohms, bridge that and you get 1 ohm.
4 and 4 in series = 8ohms, bridge that and you get 4 ohms.
Old Apr 26, 2006 | 09:25 PM
Gummie's Avatar
Car: 88 GTA
I'm going to call your post confusing for the average user. If you're confused, refer to this thread and scroll about 1/2 way down.
No, the speakers impedance doesn't change when an amplifier is bridged.
BUT
When a two channel amp is bridged to a 4 ohm speaker, it puts the same load on the amplifier as running two 2 ohm speakers in stereo. This is why most class AB amplifiers are 2ohm stereo / 4ohm mono stable. This is also why an amp would put out 50 watts x2 @ 4ohm, 90 watts x2 @ 2ohm and 180 watts x1 @ 4ohm.
Here's a little more reading
Bridgeable Amplifiers
So true, you're bridging the amp down to a 1 ohm load with two 4 ohm loads in parallel but most amp manufacturers will say that their amp is 2 ohms stable.
This is the way most people understand it so I figured I would post it.
Old May 11, 2006 | 11:33 AM
Bluestorm's Avatar
Car: '89 Formula
Does your sub have two sets of speaker terminals? wouldn't that give him 4 ohms per channel?
RazorN8
Jan 7, 2022 11:44 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
