kick panels - who makes them
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
Does anyone here still make these other than Jim? Jim is currently not taking orders and I really need a set, and I dont have the know how or desire to build them myself.
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
In a nut shell:
1 - cut MDF rings for woofer and tweeter
2 - aim the speakers (attach ring to kick pannel with some flexable metal)
3 - stretch fleece over whole kick panel
4 - apply resin
5 - add a layer or two of mat/cloth on top of that
6 - do some quick sanding
7 - finish with paint, carpet, etc
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's a lot more to it than that.
For the most part Gummie is right though. It's not beyond the realm of a "DIY" project if you've got the patience to get through it the first time. One of the harder aspects to the project is experimenting with driver positioning, which can take forever, and then figuring a way to attach your fiberglass piece to the stock kick panel, unless you want to replace the entire piece, which I never felt looked right.
Since there seems to be a lot of interest again, I'll see if I can't get a few pieces started over the next couple weeks for those who have been waiting. I finally got my workshop cleaned over the weekend, so once I get a workbench built I should be able to get started.
Car: '92 Camaro RS
Engine: 355 TPI
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
my system is all in the explorer now so i no longer have any use for my fiberglass kicks. they have holes cut for a 6.5 mid and a tweet, rezn8r made them about a year ago. 100 shipped if you're interested. if you want some pics, just shoot me a pm and i'll get some for you.
Car: 1987 Iroc-z Convertible
1st on the list let me check out some pics. droptop406@sbcglobal.net
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
send pics here to: OneFastZ@insightbb.com
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
