Dash Speakers
Old Mar 14, 2007 | 01:56 PM
BigDog99's Avatar
Car: 82 Camaro & 07 Silverado
Engine: 350 (70 Chevelle)
Transmission: 700R4 - Auto
Dash Speakers
When I purchased my 82 Camaro the previous owner replaced the stock 4x6 speakers with 5" rounds, and cut into the dash pad to make them fit. I recently purchased a replacement dash and a new set of 4x6 speakers, however I am having issues mounting the speakers. Is there a piece of hardware that these speakers are supposed to mount into? I can seem to find a place to mount the speakers, and I suspect that he removed this part when he did his hatchet job of installing the 5" rounds. Any help would be greatly appreciated.
Old Mar 14, 2007 | 03:59 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Sell the 4x6 buy a 5 1/4" component set up and mount them in the front kick panel or door. You will be much happier with the sound quality. 4x6 in the dash do not sound good.
You wil find a lot of guys have gone this route for a reason.
Old Mar 14, 2007 | 06:53 PM
cdoyle's Avatar
Yes my 84 had a metal bracket that the 4x6's mounted too.
You should be able to find one at a junk yard, or even make something yourself out of MDF that you could mount the speaker too.
Old Mar 14, 2007 | 08:29 PM
BigDog99's Avatar
You will find a lot of guys have gone this route for a reason.
Thanks for the input, but I'm more interested in the sound of the engine & exhaust, and I'm trying to make my car look nice and clean and get away from the trashy speakers all over the place look.
Thanks...I was thinking about going down to the scrap yard this weekend..last time I was there they had about a dozen old thirdgens. Maybe I'll get lucky and find what I need.
BD
Old Mar 14, 2007 | 10:40 PM
North's Avatar
Car: 1986 Camaro Z28
Engine: 400 chevy small block
Transmission: 5spd
the bracket you are looking for is rectangular 4 by 6 inches and has 4 legs sticking off of it. 2 legs bolt to top of dash fire wall side. other 2 bolt to plastic above your speedo. these brackets weren't painted so are either bare metal or slighty rusted. they also have a rubber seal if stock speakers are still there.
i hope this helps you find what you need at the salvage yard. other wise you could make your own brackets. just get a peice of sheet metal and cut out the hole for the speaker... then run it to the plastic above your speedo then to the firewall... bend this side up so it screws on flat. I hope this all helps. good luck
Old Mar 16, 2007 | 06:43 PM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Ya know I was wonderin about those 4x6 setups.Saw one at the yard recently and was interested.Don't they have a different routing of the defroster setup tubes and heater ducting than the smaller (i think it is)3x4 speakers like in my 90 R/S?Also if they don't sound that good as big as they are with no real enclosure maybe thats why GM went to the smaller setups.Have ya considered lookin into doing a swap to the smaller sets?My 120 watt kenwoods sound pretty good up there.But then again they are on a crossover so they support just the highs my sails handel the mid and the 12 in the back hatch covers all my bass.
But havin the 4x6 setup would give me more space and more options speaker wise.Like 2 sets of those 3inchers they use in my olds.Run 1 set like it is now and the other off the high output from the deck.Hmmmmmmm.Guess it's back ta the yard with a tapemeasure.
Old Mar 16, 2007 | 07:20 PM
Bill/T/D/Y's Avatar
Crap see what happens when ysa don get any sleep??I got my #'s wrong.I ment I was wonderin about those 4x9 inch setups i saw.Think it was in an 82.Ya know they are long and thin like in the back deck of a 79 cutlas.They were mounted in the front deck.Sorry gang i REALY need a vacation.this 10 a day 7 days a week with 2 hr round trip drive gets ta a fella after a while.
Old Mar 16, 2007 | 10:37 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Rear speakers in GM vehicles are typically 6x9's. The fronts in the thirdgen F-body are 4x6's. 6x9's would be a major hack job to fit in the dash.
Old Mar 16, 2007 | 11:50 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
BigDog99
The speaker mounts for the 82 camaros are not the same size for both sides. The right side is different in that it has a offset pad with a hole in it. There is a plastic stud on top of the ECM unit that slides up through the hole. It supports the top of the ECM unit, and most likley keeps it from rattling around. The bottom support for the ECM is two screws that attach to the bottom of the dash.
Let me know if you would like some photos. I have may dash cover removed and the ECM is also out. I can get photo/measurments of right speaker mounting bracket, but not the left bracket. I cannot get teh left bracket out as one of the screws next to the windsheld is stuck in the c clip used as a nut.
Dave
Old Mar 17, 2007 | 04:23 PM
Bill/T/D/Y's Avatar
Ok I know that the sails are 6x9's and the deck are typicaly 4x6 but the camaro i saw had a set of the 4x9's in it that came stock in my 70/80 olds cutlas.I realy plan ta take pix of that and measure it all out because i thought it looked odd.But i do know that ta put 6x9's in my olds back deck ya HAVE to use adaptors for them ta fit right.
I was wonderin how the 4x9's would fit and sound.If it's transferable then could be modded ta fit the typical 3.5 inchers used in the front deck of my 79/80 olds.
My inital thought train is ta have 1 system low power off the head uint and another high power off the rca jacks thru amps and apropriate crossovers.
Old Mar 24, 2007 | 09:16 PM
Bill/T/D/Y's Avatar
Re: Dash Speakers
Ok went back ta the yard yesterday.The 4x9's were in a 86 but what the owner did was remove the 4x6 brackets and just stuck the 4x9's in there.They weren't attached to anything just stuck in the space.My guess is when they tightened the dash pad down that may have held them basically in place but they HAD to sound like crap.Too much viberation from them not being bolted down.
Old Feb 26, 2008 | 07:29 PM
Bounty600's Avatar
Car: 89 Firebird
Engine: 5.7L V8
Re: Dash Speakers
Where did you get your replacement dash? Mine just cracked this year! It was the original dash too
Old Feb 27, 2008 | 06:19 PM
Bill/T/D/Y's Avatar
Re: Dash Speakers
Got lucky as heck @ a pull-a-part.The replacement started ta crack this summer too.Heat was up to 100+ so imagine it roasted it.What I ended up doin was get some fabric I liked from wally world and some spray on glue.Looks ok better than a cracked one does.Just remember to pullthe pad B4 y start sprayin or ya will coat the glass.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
