JVC head unit problems!
Old Mar 19, 2007 | 07:05 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Hi guys, I'm having a problem with my JVC kd-s12 head unit. The issue is it will turn on for a few seconds once the power is to it, but then it will just turn off. I've tried resetting as per jvc's hotline instructions. IT has constant power to it even when it turns off, hitting the power button with it off and key on on position does nothing.
So it's getting juice and not functional.
It worked absolutly perfect in the vehicle it came out of.
Post up with any ideas you may have i need help. I'm taking this car on a road trip shortly and want a functional stereo. Thanks.
Old Mar 19, 2007 | 08:08 PM
j dezzy's Avatar
Car: 87 TA
make sure its got a good ground. has a similar issue with my pioneer in my 84 and my JVC in my 91.
Old Mar 20, 2007 | 10:29 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
Re: JVC head unit problems!
i had a similiar problem to what j dezzy is talking about.. i think.. mine had power and everything.. so i added an extra ground from the outside casing to another ground point and it worked.. i would try that
Old Mar 20, 2007 | 02:27 PM
stroker_SS's Avatar
Engine: 355
I was thinking about adding another ground wire, but wasn't sure if that would work.
Old Mar 20, 2007 | 03:00 PM
j dezzy's Avatar
Car: 87 TA
Let us know if that helps out.
Old Mar 20, 2007 | 03:52 PM
Hammertime540's Avatar
Car: 91 Camaro RS
Axle/Gears: 3.42's Locker
I had a JVC unit in my car for about a year. Then one day I hopped in and it wouldn't turn on. Well I unplugged the wiring, plugged back it. Then it was going on and off constantly. Tried everything under the sun to get it to work, never did. Then I bought a Alpine unit, works just fine. I've had it for a little over a year now.
Old Mar 20, 2007 | 05:49 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
i used to have a jvc in my old camaro and sometimes it just wouldnt turn off no power or anything then it would just start working again I never could find the problem with it
Old Mar 20, 2007 | 06:09 PM
j dezzy's Avatar
Car: 87 TA
The only problem I've ever had with a JVC is that bad ground I mentioned. I prefer JVC, never had a mahor problem with them. I hate the Pioneer I have right now. And I hated my Alpine so much that I took it out of my truck and put it in my girlfriends moms trail jeep. She can deal with its crap...
Old Mar 23, 2007 | 05:43 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
First, Check the the wiring to the HU. Grounds, B+, and ACC. Wiggle them, if that makes it cut out wiggle one at a time. Gently wiggle the harness and see if that makes it cut out. Wiggle the faceplate up and down. JVCs do have problems with dirty faceplate connection, bad solder connections, and if I'm thinking of the right model, bad ribbon cables to the faceplate. Any one of them could cause the problem you described. But so could a install/wiring related problem so check there before condemning the HU.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ZsTransAm
Aug 11, 2015 07:30 PM
