did you deleted your dash speakers?
Old May 18, 2007 | 11:43 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
how many of you deleted your dash speakers, and why. i want to getting new speakers, i was going to put them back in the dash but i wanted to hear about your own experiences with spekers in dash, was it that you didnt like how they sound in there or was it that you didnt wana mess with the dash pad. i hear alot about speakers in kick panels so i want to know why people took that rout.
Old May 19, 2007 | 07:09 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Re: did you deleted your dash speakers?
I sure dont think I would want to delte mine....Cant think of a better location on a thirdgen, but im open to opinions on the subject.....I think a better approach would be to mod the dash for a bit larger speaker setup......Lets hear about your front speaker setups... Tom
Old May 19, 2007 | 07:47 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
your front speakers are were you hear all the details in the songs , the front stage is more importan then the back stage , you could delete the 6x9's would be a better choice , i also got some kick panel comp's and i COULD take the 4x6's out if i wanted but they sound good with them
Old May 19, 2007 | 08:10 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I removed my dash speakers in favor of components in the kick panels. The sound stage is much better than with the sound bouncing off the windshield but I still think it sounded good. Another thing was that it was difficult to find good dash speakers that fit a Firebird dash (don't know if the Camaro is like this) but for some reason the instrument cluster causes interference with certain 4x6 speakers. I tried both plate versions and standard cone types and still had a hard time finding some. I finally found some Kenwoods that fit and sounded pretty good but at that time I was ready to step up to components. Haven't regretted it.
Old May 19, 2007 | 11:15 AM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
i want te get some new spekers, 5 1/2 pioneer or MB quarts and was thinking of putting them in the dash, i have some 12" pioneer subs laying around in my room,they bin there for the last year or so and i'm going to put them in the back somwhere. i'm going to ditch the kenwood stereo i have right now and get a new pioneer cd mp3 player.
Old May 19, 2007 | 12:36 PM
Project Reaper's Avatar
I put 5.25" Alpine speakers in my dash and I love them.
I made some custom brackets for them but with that size of speaker you can take your stock speaker brackets out and just put the speakers in about the same place where your stock brackets where and the top of the dash will hold them in place and they will still sound very good.
I now get some very clean sound from under the dash and it makes a world of difference.
As long as you replace those factory speakers with good speakers then you will be happy with the results
Old May 19, 2007 | 02:57 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
5.25" thats cool. i have also heard of plate speakers but they may be too small
Old May 19, 2007 | 03:03 PM
Thanks.
They sound amazing and they fit nicely under the dash. Even without using brackets for those that don't know how to make brackets.
Old May 19, 2007 | 03:18 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I removed the dash speakers when I had components in the kick panels, tried 3 different set-ups, couldn't stand the loss of footwell room even with the Infinity 5.25" mids mounted flush against the metal behind the kick panel (manual car). For my new set-up I installed the tweeters in the a-pillar trim bases (molded in, looks factory) and am modifying the I/P opening in the dash to mount the mids. The passenger side had enough depth for these speakers but I was 1/4" to shallow on the drivers side. Easy modification, just need to adapt the speaker brackets to hold the mids.
Old May 20, 2007 | 03:05 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I just put sony 5.25''s in my gta i had to trim the area around the opening on the driver side and the passenger side i had no problems,now on the drivers side i didnt bolt it in and on the passenger side i could only use one screw but the dash pad itself holds them in without any vibrations or problems at all, you just have to make sure the magnet on the speaker isnt to big or it will hit the ac duct or the dash..
Old May 20, 2007 | 06:19 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Go to circuit city and they will hook you up. I have a set of pioneers that were a drop in replacement in my bird. The look stock but handle alot more power. Put in some bass blockers and a nic sub in the back and you will love it.
Old May 20, 2007 | 10:30 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
pioneer's are great , if you have subs in the back do what i did , buy some bass blockers from crutchfield for the front and back speakers and basicly dont let bass into them and just sound GREAT , my ears were killing me after i cranked my HU to see what they could handle and it went all the way and still wanted to go more
Old May 20, 2007 | 04:33 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
bass blockers... never herd of those before, but i'l look into that. so it's 5.25" that fit in the dash not 5 1/2, i wansnt sure
Old May 20, 2007 | 05:04 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
crutchfield.com has them , work great (bass blockers)
you would need to fab up your front brackets to accept 5.25's if i am not mistaken
Old May 20, 2007 | 07:13 PM
klez's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L Ported SLP Runners and Intake
Transmission: 700r4 w/ shift kit
leave them in stock position....just my $.02
Old May 20, 2007 | 08:35 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
i dont like the idea of kick panel speakers so maybe puting spekers back on the dash is not a bad idea
Old May 21, 2007 | 01:19 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Bass blockers from Crutchfield, way overpriced for what the part actually is, can be bought at most electronic stores.
Pioneer, good speakers ? Sure for the very first step up from factory, sure. But once you install a subwoofer, and you want more clarity, nope not Pioneer.
Old May 21, 2007 | 07:30 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
ok,.. so what do you recomend for subs?
Old May 21, 2007 | 08:45 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
I used the stock 4x6 spots in the dash to mount the crossovers for the components in the kick panel pods i built. front speakers are a must, but if you can afford it, get some kick panel enclosures and put a set of componenets in. night and day difference.
Old May 21, 2007 | 11:53 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
I used a single 10 inch Infinity in my own box. You could go with Ascendant Audio subs. Depends whether you want sound quality or just BOOOOM BOOOM.
Old May 21, 2007 | 11:56 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
hey, would component speakers sound good in dash or no? BTW: can i use bass blockers on tweeters too? i'l be hooking them up to the amp.
Old May 22, 2007 | 07:27 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i used 2 alpine type r's in a sealed box , the sound is crazy loud i auctly just took them out of my car casue my alarm decided to not work any more so none of my audio is in right now
Old May 22, 2007 | 09:19 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
there's just not enough room in the dash for a good set of components. the stock spots on these cars arent the greatest if you're looking to upgrade the sound. I just mounted the crossover in dash, the speakers were in the door and fiberglass kick pods i made.
Old May 26, 2007 | 02:57 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I'm running a pair of 4x6 pioneers off the amp from my headunit (Pioneer DEH-7800MP) and they don't need any bass blocking. If you've got a decent headunit you're probably throwing away money on the bass blockers... I'd put the system together and see if you need the blockers before dropping a chunk of change on them.
Old May 26, 2007 | 04:48 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
how many watts are those 4x6 speakers? BTW this is the head unit i have right now, i'l be getting a better one in the future.
these are the subs i'l be putting in the back, but i need an amp tho.
Old May 27, 2007 | 12:08 AM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
My 4x6's are 100W/20RMS, basically the older version of these: http://www.onlinecarstereo.com/CarAu...roductID=11977 I don't listen to music all that loud, maybe up to 100-110 dB at most so my experience may vary from some of you... but like I said before, it's probably worth testing without bass blockers first just to see if you need them.
Old May 27, 2007 | 02:28 AM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Originally Posted by ChillPhatCat
My but like I said before, it's probably worth testing without bass blockers first just to see if you need them.
well thats a smart thing to do
Old May 27, 2007 | 12:31 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Very good idea...You can get alot more volume, and quality sound if your front, and back speakers dont have to handle low frequencys...Most top of the line setups use some form of caps to roll off the bass....Makes a huge difference in distortion levels.You can also go to the parts store, and buy some caps for about a dollar or so...I went to EPO (Electronics Parts Outlet) and got mine......Tom
Old May 28, 2007 | 01:29 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
ok, what kind of caps are you talking about? can you post a pic please?
Old May 29, 2007 | 01:02 AM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
OMG, I haven't seen a Pioneer IMPP that looked like that since I was in high school. Two 12s sounded so good. Till I found JL AUdio. Then two 12s sounded even better. Ran them off an Autotek 44 watt, yes I said 44 watt, competition amp. That is still the most amazing amp I have ever come in contact with.
Now I just run a single JL Audio 10 off 300 watts. I wouldn't say it's as loud because the bass doesn't make my chest hurt but, it's certainly loud enough and very clean and tight. That has a lot to do with tuning oyur system though.
The caps are the same thing everyone else was talking about when they said bass blockers. It looks like a cylinder wrapped in vynal with two stiff wires coming out of each end. They all block out different frequencies though so, you need to choose wisely. Having an amp will prevent the need for these. I would try to get one that's going to block anything below 60 - 70 mHz. It all depends on how high of a frequency you let into your subwoofer through the crossover built into the amp. They need to match closely to the sub cutoff or, you're going to have a gap in your audio playback.
Good speakers should be able to handle a 60 mHz playback because, with a good sub and amp you shouldn't need to have the bass cranked up on the head unit.
Old May 29, 2007 | 08:00 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
i feel you man and yeah those pioneer subs are kinda old, my friend had them in one of those bass boxes for a long time, then one day he needed money and i did him the favor for $100 bucks. say, how many watt amp would be good for these 450 watts subs?
Old May 30, 2007 | 07:45 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
60 MHz You must have amazing hearing!
Old Jun 1, 2007 | 02:35 AM
racer J's Avatar
Engine: 305 TBI
Yea I'm half alien so I have hearing beyond you full blooded earthlings lol.
What subs are you wanting to run 450 watts to? Is that peak or RMS? How many subs?
I'm rather fond of MTX these days. The Thunder TC3001 I have pushes 300 watts a 2ohm load to my DVC JL AUdio w12v3. It actually pushes more than that. The amp is rated at 300 RMS but, it tested at 350 watts RMS. My amp is discontinued though. It's also very small and compact. You might be able to find something in that series on clearance somewhere or online at a good price instead of purchasing the large and bulky model that replaces it.
Old Jun 4, 2007 | 03:06 PM
Thestriped1's Avatar
Car: 89 2.8 RS
Engine: the 2.8
Transmission: 700r4 auto
Axle/Gears: stock one wheel squealer
Delete them. If you replace them with kick panels that have components speakers you will obtain better sound from your set up. If you havent already noticed it sounds like most of your music is coming from the left. well our cars unfortunately have poor speaker placement. that speaker right in front of your forces you to hear that speaker first and loudest by moving the speakers down to the kick panels you change the distance ration to your ears allowing for a more encompassing audio experience. Also the tiny speakers in the dash are not made to handle bass so they will tend to blow out unless you set up bass blockers on them or and eq or you have a deck that will allow you take the bass off of the front speakers or all speakers and only run bass to a subs. all in all the 4x6's suck and cant handle much bass because the coil will over heat. if i had known i wouldnt have bought them cuz now i pretty much have 4x6 tweeters
Old Jun 19, 2007 | 03:38 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
I have 3in seperates in my dash and kick panels. The brand is all kicker.
MantyZ28
Nov 8, 2015 06:54 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
