Trouble with my Bose system
Old Dec 29, 2007 | 10:04 PM
blkiroc87's Avatar
Car: 1987 IROC convertible
Engine: 305 t.p.i
Transmission: 5 speed manual
Axle/Gears: Borg-warner 3:45
Hope someone can help, I've got a 1988 IROC with the bose system in it. The problem I have is that the front speakers make noise but not a hum or buzz. Its kind of like a dull squeak that changes in freq, but is constant with the volume at any point. The drivers side speaker dosent sound very strong. The person before me who owned the car installed a pioneer 6 disc changer in the rear pit. The system dosent wire to any speakers though, its runs through a FM radio freq. The car only has 2300 miles on it, so the radio hasent had alot of use. Also the noise is there with the engine off or running. I dont think its an interferrance thing. Any help or advice would be good. Thanks
Old Dec 29, 2007 | 11:08 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: Trouble with my Bose system
Wait...you have a car with 2300...or 23,000?? Either way, sweet
Anyway, when you say it changes in frequency, does it do it with the car off and/or does it change when you hit the gas/change rpm's/load. Also, does it only do it when your using the CD player or does it do it no matter what you use?
It sounds like a grounding problem, maybe head unit or CD changer related .
Old Dec 30, 2007 | 08:20 AM
blkiroc87's Avatar
Engine: 305 t.p.i
No you read it right, actually its 2,385 miles all original. As I said I don't spend a lot of time in the car! but sometimes I just sit in it in the garage and listen to the radio, sounds weird huh. It will make the noise with just the ignition in accessory position. If I turn the vulume down all the way the noise is the same but only from the front speakers. The engine dosent need to be running but will be the same if it is running. The cd changer is not hard wired to the speaker system, it runs through a FM modulator. I've got a service manual but these manuals say nothing about the Bose system.
Old Dec 30, 2007 | 08:56 AM
blkiroc87's Avatar
Engine: 305 t.p.i
One other thing, milage is 2,285. I just totally disconnected the cd player and this didnt change a thing! I'm starting to think it may me a amp or something like that thats out.
Old Dec 30, 2007 | 01:40 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Well, that's a tricky one
I guess it might be coming through your front speaker wires from somewhere. Does it happen if your in accessory with the stereo off? If so, that would support the noise coming through the speaker wires theory.
Other then that, maybe your head unit is messed up. I had a pioneer do that to me, but it only happened with the car on, so I'm not sure that it would be something like that.
I'm not really sure what to tell you, maybe someone else has some more info on it.
Old Dec 30, 2007 | 02:06 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Try another speaker, if not it then check th amp, by hard wiring a speakerto the radio. good luck
Old Jan 10, 2008 | 09:36 PM
blkiroc87's Avatar
Engine: 305 t.p.i
This may help someone out there. The delco bose system will not work with just any aftermarket speaker. Each speaker has a powered amp plugged into each speaker. There was a common problem with the front amps, the capacitors inside would go bad, infact some were bad the day they were installed new. Its very easy to remove the amps from the cased unit. I sent mine to a place called Precision radio they are located in San Antonio TX. They have over 25 years of experience in these systems. They are also very helpful in explaining just how to take the unit apart. But just about any noise or problem with these front speaker units can be because of a bad amp.
Old Jun 21, 2008 | 12:05 PM
tomcamaro's Avatar
Thanks for the info, I trace down the loud tone noise to a bad amp in the front sail panel. But removing the carpet around the amp assembly would be a pain. If the capacitors are the reason, I probably replace the electrolytics first. I heard back in the 80s that those types of capacitors degrade over time.
RaverRacerX
Mar 17, 2026 01:49 AM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
sailtexas186548
Feb 17, 2017 03:07 PM
BWilcox
Sep 20, 2015 12:19 PM
scottmoyer
Sep 7, 2015 07:06 PM
