stock speakers
Old Feb 5, 2008 | 12:28 PM
brentb's Avatar
stock speakers
What is the size of stock speakers in a 92 camaro I was going to put in aftermarket speakers. And what would be the best to fit in the stock place?
Old Feb 5, 2008 | 12:38 PM
L0tuS's Avatar
Re: stock speakers
4x6 in the front and 6x9 in the rear
Old Feb 5, 2008 | 09:19 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: stock speakers
i like infinitti kappas in front and rear but, it's all preference......
Old Feb 7, 2008 | 09:53 PM
terrorhertz's Avatar
Car: '88 IROC
Engine: 305 TBI LO3 for now
Re: stock speakers
take care in picking the 4x6s. many on the are too deep. Check the mounting depth for your year car before buying. Many of the better speakers have larger magnets that don't fit.
Some people have still used such speakers by putting spacer rings in . Sometimes haveing to cut out material on the underside of the dash pad.
Crutchfield used to publish this data. Bosch makes a book that will tell you. but it is expensive for doing just one install. You could measure it yourself. I wnet to Crutchfield and looked at the speakers that fit my car and noted the depth of those. then I looked at the speakers that they didn't recommend to see what depth didn't fit. This gave me a close approximation of what would fit mine.
Old Feb 7, 2008 | 09:59 PM
Car: '88 IROC
Re: stock speakers
You can also get 3-4" 2ways that are made into a 4x6 plate mount. Or 4x6 components and mount the tweeter on the pillars.
Old Feb 8, 2008 | 09:24 PM
Kevin B.'s Avatar
Car: 1991 Trans Am
Re: stock speakers
Kraco's, after all it is a s"LO3"w ****** machine....
Old Feb 8, 2008 | 09:55 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: stock speakers
i used to have pioneer 4x6 3 way speakers up front in my last car. they were quite awesome actually. i paid $100 for a pair. they were on sale. they were on a different car tho. but they didnt have to deep of magnet or anything like that from what i can remember.
im in the process of looking on what type of 6x9 speakers.
i like the 3 way speakers best but thats my opinion anyways.
Old Feb 8, 2008 | 11:53 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: stock speakers
^^I have those 3 way pioneers in my Firebird right now, got em for 40 though ...they kind of suck
I've heard of 5.25 inch speakers in there, when I have some extra cash I'll take some measurements and do some cutting to see if I can pull those off in the front. It would be a million times better. Imagine this, 5.25 inch CDT components up front running at 200 watts rms each, then topped off by 2 12's (brand/type undecided) behind the front seats in a fiberglass enclosure running at 600 watts rms each...
As for the rear speakers, well I plan to do away with mine, but I would go with some 6.5 inch speakers for there.
Old Feb 9, 2008 | 12:39 AM
Kevinn's Avatar
Car: 1992 Z-28 25th Ann Edition.
Engine: 5.7 TPI
Re: stock speakers
For your speakers you are gonna want to get some nice Plate 4x6 speakers.
And for your rears I would go with some nice 6.5 midbass drivers.
You can easily fit the 6.5's with a 6.5 to 6x9 adapter.
Get these..
http://www.sonicelectronix.com/item_...+462.7cfp.html
http://www.sonicelectronix.com/item_...ker+SSMB6.html
http://www.sonicelectronix.com/item_...sche+SA69.html
REMEMBER. All of this can be found on ebay for MUCH much cheaper.
Hope this helps you out! I use this setup in my car, and I love it!
Old Feb 9, 2008 | 12:44 AM
joshh44's Avatar
Engine: engineless
Re: stock speakers
have you guys every tryed using 6x9 speaker boxes? how do they sound? i was thinking of getting good set of speakers and get some speaker boxes for them. the speaker inclosure in the pannels in the car are all torn and riped into shred. dont ask why but they were.
im wonder what to do about that.
i was thinking of mounted them on the top of the fuel tank hump. right behind the passenger seats.
Old Feb 9, 2008 | 12:46 AM
Kevinn's Avatar
Engine: 5.7 TPI
Re: stock speakers
To be honest with you, your 6x9's are very overrated.
If you want good sound quality I would get some nice 6.5 midbass speakers.
Like these...
You can probably find some kick panels for them too, and just put them in the front, along with your 4x6's.
Old Feb 9, 2008 | 12:53 AM
joshh44's Avatar
Engine: engineless
Re: stock speakers
i will probably get some 6.5 for the rear. i been hearing alot about 6.5 being really good sounding speakers.
i was reading someone put a 5.1 surround in there car. that was an interesting write up. having a speaker up in the middle of the car.
it was in a fiero but similar to are cars. just camaros are bigger haha.
im not looking to go into any crazy sound compitions or blasting my ears till the bleed eather.
something with good sounds better then the stock. somthing more crisp and clear.
what about subwoofers? i hear 12s are abit much for a nice crisp sound. 12 tends to be alittle muddy. what are your words on that?
sorry for kinda stealing this thread. ill give it back now
Old Feb 9, 2008 | 12:55 AM
Kevinn's Avatar
Engine: 5.7 TPI
Re: stock speakers
Pm'd you josh.
Old Feb 9, 2008 | 09:51 AM
brentb's Avatar
Re: stock speakers
You think you are better with your LB9 but whos car is running and whos engine is in my garage not put together
Old Feb 9, 2008 | 04:59 PM
Kevin B.'s Avatar
Car: 1991 Trans Am
Re: stock speakers
I could push my engine stand aound faster than your car big boy....
Old Feb 9, 2008 | 06:16 PM
brentb's Avatar
Re: stock speakers
If you think you can come get your engine stand out and lets race
Old Feb 28, 2008 | 01:57 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: stock speakers
i been thinking about infinitiy kappas or the new perfects but i was told that they where to deep for the dash and i would have problems with the rear fitting i have 92 ta vert with 6.5 i believe they change from 6X9's to 6.5's during the converison
Old Feb 28, 2008 | 02:19 PM
brentb's Avatar
Re: stock speakers
I have bouht speakers and installed them and everything fits fine. Thanks for your post and help. If i have anymore autio ? i will post up for your guys hepe, Agian thanks for your imput.
Old Feb 28, 2008 | 02:39 PM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: stock speakers
what speakers did you go with?
Old Feb 28, 2008 | 03:01 PM
brentb's Avatar
Re: stock speakers
I went with infinitiy 6x9's for the rear and pioneer 4x6 for the front? I had infinitiy's for the front but the mag and base was to thick to fit. It hit the air ducking in the dash?
Old Feb 29, 2008 | 03:29 AM
Car: '88 IROC
Re: stock speakers
So how's it sound?
Old Feb 29, 2008 | 10:31 AM
brentb's Avatar
Re: stock speakers
It sounds good? I install home audio and, the car audio is basicly the same way. You just have to run the right size wires,and run a good ground. What i mean by right size wires is take all the stock wires out. And run a good size guage wire?
Genopsyde
Oct 7, 2015 08:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
