power antenna
Old Jun 2, 2008 | 12:12 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
power antenna
i recently purchased a 1987 iroc and i am trying to get the power antenna working. there is a blue wire in the hole for the stereo.. so i hooked it up to the blue wire coming out of the cd player. i got nothing. i don't believe the motor for the antenna is even trying to do anything. am i missing something or is my motor fried?? any help would be greatly appreciated.
Old Jun 2, 2008 | 12:59 PM
orez_28's Avatar
Car: 1987 Z-28
Axle/Gears: Posi/2.73
Re: power antenna
remove the passenger side cover and locate the wires going to the power antenna (white, green, gray) to see if they have bin cut.
Old Jun 2, 2008 | 03:01 PM
Re: power antenna
ok.. if they are in tact do you know where they are supposed to be connected?? i am guessing black is the ground? ..sorry if i sound like a dumb @$$ but i have never had to deal with these before. ...thanks for the help.
Old Jun 2, 2008 | 07:03 PM
Re: power antenna
ok.. the green and white wires are cut down by the antenna.. i couldn't tell where they are supposed to go.. anyone know??
Old Jun 2, 2008 | 08:28 PM
Re: power antenna
i took the antenna out far enough to see the wires (on the backside of course) and was able to strip them and hook them back up. BUT when i had the green and white wires that go into the car stripped they touched the fender and put on a little show (sparks! (the key was off)). now i don't have any power AT ALL to my radio.. i checked the fuse under the dash as well as the in line fuses for the radio and all is well.. any ideas as to what i screwed up now?? it's been one of those days where i try to fix something only to break something else!
Old Jun 2, 2008 | 09:14 PM
Johnx's Avatar
Car: 1990 Iroc
Engine: 383
Transmission: th350
Axle/Gears: 4.10
Re: power antenna
Aftermarket radio with a fuse on the back of it?
Old Jun 3, 2008 | 07:34 AM
Re: power antenna
yeah it's an aftermarket radio.. i didn't see a fuse in the back of it.
Old Jun 3, 2008 | 07:41 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: power antenna
Follow the yellow and red wires from the back of the radio, and look for a fuse holder like this:
And see if it's popped.
Old Jun 3, 2008 | 09:05 AM
Re: power antenna
checked them.. they are good.
Old Jun 7, 2008 | 09:36 PM
Re: power antenna
ok.. i feel stupid. i had checked all of the in-line fuses and the fuse labeled "radio" in the fuse block and all checked out. today i checked the rest of the fuses and the one marked "accessory" was blown.. i replaced it and my radio works! BUT with the antenna hooked up the motor would just run and run.. would that be a screwed up motor or is the cable that runs it broken?
Old Jun 8, 2008 | 12:16 AM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: power antenna
if the motor runs .....then you have a broken cable ...i just replaced mine and works like new
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
