New Sub Box
Old Jul 29, 2008 | 05:31 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
New Sub Box
Built it myself over the past couple of days. It needs some carpet and tweaking but I'm happy with it. Now I just have to find someplace to put my amp.
Old setup:
Old Jul 29, 2008 | 05:36 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: New Sub Box
Is that mounted in a box or did you cut the interior panel and mount it
Old Jul 29, 2008 | 05:43 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: New Sub Box
It is mounted on a box that is where that little storage space is, I cut that out and build the box to slip in there.
Old Jul 29, 2008 | 06:46 PM
BMAN90RS's Avatar
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
Re: New Sub Box
looked like it was fine as it was. how does it sound?
Old Jul 29, 2008 | 07:46 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: New Sub Box
Sounds much better than my last box, that last one wasn't enclosed like this one is.
Old Jul 29, 2008 | 09:16 PM
hellsatan's Avatar
Car: 89 IROC
Re: New Sub Box
your other box looked better and cleaner. I'm not a huge fun of mounting subs like that.
Old Jul 29, 2008 | 09:35 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: New Sub Box
Your old setup looks very similar to my current one, however mine is a sealed enclosure. Personally, I like the looks of your previous setup, but since the current one is sealed, should do much better.
Old Jul 31, 2008 | 07:15 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: New Sub Box
I redesigned after not being that happy with the first. It still needs carpet but I'm very happy with it this time.
Old Jul 31, 2008 | 04:09 PM
hellsatan's Avatar
Car: 89 IROC
Re: New Sub Box
that looks much better. carpet it up and it will blend in and make a cool stealth box look. hide that little wire and you sir have a nice box
Old Jul 31, 2008 | 04:43 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: New Sub Box
I'm going to do just that, I just want to find a place to hide my amp as its just sitting in the bottom of the trunk. For the carpet I just need some good spray-on adhesive
Old Jul 31, 2008 | 08:26 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: New Sub Box
Good stealth box. My it's the best sub enclosure for the thirdgens.
Old Jul 31, 2008 | 10:44 PM
ParkerTPIz's Avatar
Re: New Sub Box
looks good. ive got a buddy that wants to do something similar to that. i will recommend he take a look at this thread.
Old Jul 31, 2008 | 11:57 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: New Sub Box
WAY nicer, was the first box just a board that laid over the hatch area? You should spray that box down with bedliner in case you get water back there, plus it'll match the plastic trim it's mounted in.
Old Aug 1, 2008 | 09:07 AM
rusty83TA's Avatar
Re: New Sub Box
I'm definitely gonna try something like that after seeing how well yours turned out. I'm thinking of trying a little fiberglass to help blend in the curves.
Old Aug 1, 2008 | 04:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: New Sub Box
First one was a box, just built it in a hurry, I missed my base after pulling my sub for autox on sunday. I didn't think about bedliner, thats a great idea and may do that.
Old Aug 1, 2008 | 06:21 PM
Re: New Sub Box
The bedliner you get in cans from Wal Mart works great, it doesn't have a textured look to it unless you really want it to, it usually comes out pretty smooth and actually almost mimics the finish on the factory plastics. I've been using it non stop since I found some cans of white on sale for $5 a can.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
