Help me figure out whats wrong with my system?
Old Aug 22, 2008 | 12:43 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
hello all ,
the system includes :
one 5 chl amp ( infinity)
two 4x6 front inifinty
two 6x9 infinity
pioner head unit
poiner sub/box
three sets of rca cables
bass controle and remote
ipod connection
the problem\
turned car on everything sounded ok.
I went to my car after work, to get my tools out. After turning she over I notice something is wrong. I Hear a constant high pitched sqeal souded like coming from the speakers. When I gave her some gas the wine increase as i gave it more gas.
PLEASE help me find out what this wine is from and why it increases with rpms going up?
Old Aug 22, 2008 | 05:16 AM
scrapegoat's Avatar
Re: Help me figure out whats wrong with my system?
Sounds like a bad ground somewhere in your system, ill wait for someone else to chime in
Old Aug 22, 2008 | 02:29 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Unplug the RCA's from the amp, see if you still have the noise...
If no, check for nicks or reroute them...
If yes, check grounds on all equipment...
Raf
Old Aug 22, 2008 | 05:39 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
does it make adifferenace that i wired em right next to the power wire?
Old Aug 22, 2008 | 06:40 PM
luvofjah's Avatar
You're supposed to run them away from each other...
Old Aug 22, 2008 | 07:52 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
possible problems:
1. head unit may be going bad because that may be alternator whine. The head unit is supposed to 'dampen' or not allow that power sound to go into your audio
2. if head unit good, everything else is fine, you may have the ground too close to your power source
no matter what the cause its definitely alternator whine, raw electricity is getting into your sound output.
Old Aug 22, 2008 | 08:31 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
my ground is where the jack was held down on, used same circal shape bolt and screwed it back on.
head unit is good or should be good all the components are new installed yesterday
Old Aug 23, 2008 | 02:18 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
also, along with what these guys said, make sure that there is no paint on the ground screw/area as well. take a flathead screwdriver and really get the paint off the area you are grounding to. but its definitely a grounding issue.
Old Aug 24, 2008 | 08:29 AM
cdoyle's Avatar
Raf
Did you do this yet?
This test really helps narrow down where the engine noise is coming in at.
Old Aug 24, 2008 | 08:43 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
im almost positive that im picking up my altanator
Old Aug 24, 2008 | 01:41 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
toxik you HAVE to move the RCA's away from that power wire. I can almost guarantee you that is your problem. If not you have a bad ground somewhere.
Re-route the RCA's before continuing to look for an easier fix.
Old Aug 26, 2008 | 09:05 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Definetly reroute the rca's on the opposite side of your power wire first.If it still makes noise it shouldnt be nearly as bad.Then one at a time unplug each rca from the amps while the car is running and really isolate which rca is picking up the noise.If you cant narrow it down to just a single rca that may be nicked then you have a ground issue from either bad amp to ground,radio to ground,bad motor to ground or battery to ground..or..all of the above depending on the shape of the car entirely.Here is the quick tests we do at my shop.Cut a piece of trigger wire about 15ft long.Slide the radio out so you can access the rear of the radio.Start the car and turn the volume right down so you can truly hear the engine noise.Now strip both ends of the wire you just made.With your system on and completly wired up as you have it..touch one end of the wire to the chassis of the radio and hold it there,touch the other end of the wire to the outer metal contact of one of the rca's plugged into the 4channel amp.This will either make the noise worse..or go away.Try that and let us know,it will answer a few questions I have.
Old Aug 26, 2008 | 09:08 PM
luvofjah's Avatar
Also, cheap RCA's that have no nicks and look perfectly good can be bad and cause problems too...
Raf
Old Sep 12, 2008 | 05:45 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
I know you probably fixed it by now but check your remote wire where is it beside the power wire? If so that is your problem. If your ground was bad your system wouldnt work. I have never had a whine come from my rca beign next to my power wire, it has always been the remote wire beign beside the power wire. Run your power wire down one side of the car and the remote wire down the other side that should take care of it.
Old Sep 12, 2008 | 08:43 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
its fixed but thanks
Old Sep 13, 2008 | 03:59 PM
JohnLarson66's Avatar
Car: 1989 IROC-Z
Engine: 5.7
For future reference, what was the problem? How did you fix it?
Old Sep 13, 2008 | 06:08 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
The problem was : I ran the rca cables and the power wire and speakers on the drive side. hearing alt wine
soulution : Re roughted the rca cables to the other side of the car so i would not pick up alt whine thought the speakers.
Cornholio7979
Sep 20, 2018 02:31 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keith5
Aug 27, 2015 04:37 PM
