Odd audio plug
Old Nov 19, 2008 | 10:38 AM
gangsta_money23's Avatar
Car: 1982 Camaro Z-28
Transmission: manual
Odd audio plug
ok so now to make things even more fun i was lookin through all the audio wires I have comin from the car and i found some plugs with wires still attached to them.One looks like a factory audio harness but the others are little round plugs. Im not sure if they are stock or not but if anyone has any ideas thatd help alot. i attached pictures of them. plug 1 each wire has a letter above it on the plug. the black wire is A and it goes through F which is the yellow wire. plug 1 looks like a wire harness but the colors dont match up with the ones i found for my car. anyone know what any of these plugs are? thanks alot and none of them connect either i allready tried em all.
http://farm4.static.flickr.com/3282/...124904.jpg?v=0 plug 1
http://farm4.static.flickr.com/3282/...3deb79.jpg?v=0 plug 2/3
http://farm4.static.flickr.com/3039/...dcd1b5.jpg?v=0 plug 4/5
Old Nov 19, 2008 | 10:47 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Odd audio plug
Those links don't bring up pictures for me.
Old Nov 19, 2008 | 10:52 AM
Re: Odd audio plug
http://farm4.static.flickr.com/3282/...3deb79.jpg?v=0 2/3
http://farm4.static.flickr.com/3039/...dcd1b5.jpg?v=0 4/5
ok thesd should work i just checked em sorry
Old Nov 19, 2008 | 03:15 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
Re: Odd audio plug
Plug 1 looks like the ones for the auto tranny hookup on the shifter,and plug 4/5 looks like lower dash panel lights at least the orange and white wire one does,the darker color wire one may be for the heater light or maybe the auto shifter bezel.
Old Nov 19, 2008 | 03:47 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: Odd audio plug
Is your car a manual trans? The 82-83 cars at least still had the big auto trans connector even if the car was a manual from the factory, the harness was universal. I was very surprised to find that when I did my manual to auto conversion on my 83 that the plug for the shifter was already there and I just plugged it in and the backup lights worked. That big flat one is the auto transmission shifter plug. It switches back up lights, and also tells the ECM whether the car is in neutral or a forward gear (park/neutral switch flag)
Old Nov 19, 2008 | 03:55 PM
Re: Odd audio plug
I didnt think of that being the auto shifter hookup. I know the transmission was swapped to a 5 speed but i dont remember if it was manual or automatic before. well if none of them were audio plugs then the previous owner took all the wires out completely since there werent any others in there so I get to completely rewire from audio from scratch
Old Nov 19, 2008 | 04:10 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Odd audio plug
Im guessing it was origionally an auto, in your middle picture in the backround see the black tube with the piece sticking out with a hole in the middle? Thats the shift interlock cable.
Old Nov 20, 2008 | 11:29 PM
Re: Odd audio plug
for some reason I didnt even notice it. Thanks for all the help though. Saves time testin every single wire. Looks like this weekend I get to rewire everything audio related which is fine with me, lets me make sure its done right an I wont have anyone else to blame later
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
Fronzizzle
Sep 8, 2015 12:10 PM
89 formula TPI
Sep 7, 2015 11:06 AM
