Custom Box Size (Check Out)
Old Nov 23, 2008 | 01:37 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I'm in need of "perfect" sizing of my back inner trunk size. I'm in need of wanting to make a custom subwoofer box; just need the dimensions and information on it. I have a 1989 Camaro RS. Black interior. (i'm looking into carpeting the box as well.
regards,
Timinsk
Old Nov 23, 2008 | 04:12 PM
SilentBobZ28's Avatar
Car: 2014 2SS/RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.55
Re: Custom Box Size (Check Out)
Your best bet is to measure it yourself and build to your subwoofer's specs. If you are running 1 sub, it will need less air space than 2. Each subwoofer brand has it's own "perfect airspace" for each sub. I Custom built a box for my buddies solobaric square 15 for his camaro. It took a lot of measuring and math to get the dimensions correct for the airspace needed and so the box would have a "factory look and fit. Just like everything. Measure twice, Confirm everything, make a good blueprint, so you only have to make one cut.
Old Nov 23, 2008 | 07:38 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
yeah thats basically what i know of; i just wanted to see if anyone already had premeasurements so i dont have to go through the hassle :P
Old Nov 25, 2008 | 02:17 AM
zach113092's Avatar
something like this?
https://www.thirdgen.org/forums/car-...l-sub-box.html
sorry if thats not what you're talking about, hope i helped.
Old Nov 25, 2008 | 05:14 AM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
i have an 89 camaro and i just built a top that layed on top of the trunk area. i had to 12" subs in it and it sounded great. alot easier than building a box. it uses the trunk space as an enclosure.
Old Nov 25, 2008 | 08:03 AM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
I just finished my custom box for my 1992 Camaro. I also put it in the well area. Here are the plans that I used to build the box but I used them as a guide to get the idea, always meassure and figure out how much air space your subs need.
Also if you want to see how my box turned out check out this thread..
https://www.thirdgen.org/forums/car-...box-check.html
Model1[1].pdf
Hope this helps in what you are looking for,
-Darren
Old Nov 25, 2008 | 09:51 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
That helped alot as well; thank you for your help
Sounds good; but I don't really mind building my own box; itll keep me doing something :P hehe
Attachment 167602
-Darren
Thank you so much! Thats exactly what I needed!
Old Nov 25, 2008 | 10:00 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
It was fairly easy tho, Just one sheet of 3/4 inch MDF and a good table and jig saw and you are in business. Building the bottom of the box was easy just a lot of small pieces, the top you have to custom make and fit yourself, all depending on how you want it too look. I went with the flush look all around just my opinion but I love the way it turned out and looks. Make sure you post a thread showing us your progress when you get started! I love car audio and love to see other peoples installs!
Glad I could help! Good luck on your build!
-Darren
Old Nov 25, 2008 | 10:15 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Thanks!
Old Dec 22, 2008 | 09:28 PM
lil tp1983's Avatar
Car: 92 RS
Transmission: TH400
Axle/Gears: 2:73
I HAVE A 92 RS I'M THINKING OF PUTTING TO 15'S IN THERE AND WAS WONDERING HOW IT WOULD LOOK IF ANYONE HAS DONE IT CAN YOU POST SOME PICS BECAUSE MY LOCAL SOUND SHOPS SAY THAT IT IS IMPOSSIBLE TO PUT 15'S OR 3 12'S IN A 92 CAMARO
Old Dec 22, 2008 | 10:29 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
First off nothing is imposible, I have not seen 2 15's in the hatch of a thirdgen but I am sure it can be done. I have seen 3 12's tho so I know that can be done as well. I will try to find some pictures and post them here for you. Just one question are you sure you need all that bass in a thirdgen? I have 2 12's and in that hatch it sounds great but turned up all the way it is too much!
-Darren
Old Dec 22, 2008 | 10:59 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Here's a picture with 3 12's I couldnt find one with 2 15's but I am sure it can be done...
c%3A%5C%5Cdocuments%20and%20settings%5C%5Ckids%5C%5Cmy%20documents%5C%5Cmy%20pictures%5C%5Cnew%20fol
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
