Delco radio is locked
Old Apr 6, 2009 | 07:07 AM
Jason444's Avatar
Car: '92 Formula, '92 TA, '91 ZR-1
Engine: 350, 305, LT-5
Hi everyone,
The factory Delco radio/CD on my '91 has locked up and only displays 0:00. The previous owner put a new battery in just before I bought it and when I went to look at it, the radio was locked up. Is it possible to unlock it, and if so how? I checked the manual and it said something about a six digit code but I don't have a clue what that number is. Is there any way to reset this or am I out of luck?
Thanks,
Jason
Old Apr 6, 2009 | 09:12 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Delco radio is locked
Chevy dealer might be able to help you out on that. I know there is a back door way to unlock a 4th gen radio so i would assume that you could do it as well with a 3rd gen radio, but i am unaware of the technique to do so. Contact your local GM dealership and they should be able to help you out. Be prepared to get charged an arm and a leg for the unlocking. After that i hope the CD player works...
Best of luck,
Jon
Old Apr 6, 2009 | 10:29 AM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
or try delcolockcodes.com Theres a small charge but it works out and beats a dealership price.
Old May 17, 2009 | 02:59 PM
PurpleHazeZ28's Avatar
dealer did mine for 10 bucks and gave me the code
Old May 17, 2009 | 04:20 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Jason...........Shoot me a e-mail as I have a link to unlock most pre-03
Delco units. Don't want to post it on a open forum.
Old May 21, 2009 | 11:56 AM
Jason444's Avatar
You have mail.
Old May 21, 2009 | 12:06 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
On my 1989 with the steering wheel controls all I have to do is press the "mute" button.
Old May 22, 2009 | 06:34 AM
Jason444's Avatar
UPDATE - I cannot retrieve the codes from my radio to get it unlocked because it only reads 0:00 and the volume bar triangles are at about six. I have tried the button pressing sequence to get the radio code, but the display will not change from 0:00. Am I out of luck or is there something else I can do?
Thanks,
Jason
Old May 22, 2009 | 11:46 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Jason......That procedure I sent should work. Its sort of tricky to do as it
took me a few trys to get it to work.
I guess then its off to the dealer as the last resort
Old May 22, 2009 | 03:59 PM
Jason444's Avatar
I'll try that again after I do the radio disconnect/reconnect. Thanks!
Old May 24, 2009 | 11:50 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Jason.......Does your radio say LOC ?????????
OR when your going thru the unlock procedure I sent and when
you go thru the procedure it then shows 000 on the display?
When it shows the 000 this is when you punch in the "code" number.
The code you must punch in is in the instructions I sent.
The radio itself does NOT give you the codes!
The code just unlocks the radio..................
Old May 25, 2009 | 05:44 PM
Jason444's Avatar
That has been my issue the whole time...the display has NEVER said "LOC" as long as I have had the car, it only says 0:00 with the volume triangles at 5 or 6 bars and will not change regardless of which buttons are pressed or for how long. It was that way when I bought it and the guy said the radio worked until a couple days before when he changed the battery. Is there a chance it is not locked, just dead?
Old May 26, 2009 | 09:09 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Jason.....Check your mail !
Old Nov 9, 2009 | 03:15 PM
missabe's Avatar
I need to unlock a delco radio in a 1999 pontiac bonneville.
Old Nov 13, 2009 | 09:52 AM
mpg12671's Avatar
Car: 87 89 t/a
i need to unlock the radio in my 89 gta code says loc . can someone send me the sequence
Old Jan 19, 2010 | 01:03 AM
88iroctpi305's Avatar
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
i need to replace my bose HU with a after market HU n e one know where i can get a wire harness?(i have a 88 camaro iroc btw) or do i need to re wire. ive been getting different nswers from different places all the time.
Old Jan 19, 2010 | 09:44 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
You can get wiring harness from wal-mart for $10-$12. just pick one up and swap the units If you don't need it take it back.
Old Jan 19, 2010 | 12:06 PM
well see i have three actually. one from wall mart,advanced auto,then crutchfield but none of em work? i dunno. but they just wont plug into my couplers from the factory harness.
Old Jan 19, 2010 | 03:17 PM
Car: 1987 Trans Am
Engine: tree-fiddy
Can you post a picture of your current connector. And if you have the part# from one of your adapters?
If all else fails cut the connector off and just hard wire it to the adapter that comes with the new headunit. get the wiring diagram for the new unit and the factory wiring and just match them up.
Old Jan 19, 2010 | 03:18 PM
Car: 1987 Trans Am
Engine: tree-fiddy
Backfire
Old Jan 19, 2010 | 04:34 PM
here are the pics of my couplers and my connector. i will also send you the link that i got the conector from
http://www.crutchfield.com/p_142C4GM...&ssi=0&tp=3486
Attached Thumbnails Delco radio is locked-radio-harness-001.jpg   Delco radio is locked-radio-harness-002.jpg   Delco radio is locked-radio-harness-003.jpg
Old Jan 19, 2010 | 05:08 PM
Car: 1987 Trans Am
Engine: tree-fiddy
If it doesn't fit they either sent you the wrong part your you don't have a real Bose head unit.
How far off are the connectors?
Assuming it doesn't rain tonight, I'll take a pic of my wiring harness and you can compare it to yours unless someone else has handy the stock harness and Bose harness for reference???
Old Jan 19, 2010 | 07:30 PM
yes that would be great. but they are not that far off. maybe i just need to fitle with it some more. but if you could post some pics i would appritiate it.
Old Jan 19, 2010 | 10:08 PM
Car: 1987 Trans Am
Engine: tree-fiddy
Sorry it was sprinkling a bit when I got home so I didn't take any pics.
Do you have 2 or 3 plugs from the old unit? Do they look like all of them plug into the one adapter you have? It might just be a bad molded recepticle on the adapter. I've seen harnesses with some **** poor quality and had to do some shaving of plastic to get everyting to fit.
Old Jan 19, 2010 | 11:04 PM
its cool man. and there are three plugs from the old HU to of them look the same and the other is totally different(the black one behind the radio)
Old Jan 27, 2010 | 12:27 AM
joefinn71's Avatar
you will need a bose adapter you will have to go to a stereo shop or best buy to get it.they will need to know the year and make of the car.if they dont have it you may just want to go ahead and replace the speakers because the radio will not play the factory bose as the ohm load is to low and will fry the radio
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
