Wok Box. Will it work?
Old Nov 20, 2009 | 04:48 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
I originally had a sub box in the cargo area but I scrapped it and made a lid for the cargo area with a hinge and made the subs built in with the amp mounted on the floor underneath. I noticed a serious loss of bass power when i did this, i;m guessing it is because the subs aren't sealed and sound is escaping downward. I was thinking about using either a mixing bowl or a wok (purchased from "Bed, Bath and Beyond") to seal each sub... Will it work?? i don't see why not but i'm just a novice...
Thanks!
Old Nov 20, 2009 | 08:04 PM
boldguy's Avatar
Car: 1992 Z28
Re: Wok Box. Will it work?
Is there a disadvantage to using a metal material behind the sub??
Old Nov 21, 2009 | 01:03 AM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
By placing a bowl behind the sub you are gonna limit the space it has to breathe, different subs require different enclosures where they sound better,theres free air subs that will perform well in an infinite baffle (no enclosure) like say in the rear deck of a car.
I'd personally wouldnt try it....
and 2nd if you use a metal material behind the sub is gonna rattle like a bitch unless you deaden the hell out of it,is there a reason why u wanna do that?
Old Nov 21, 2009 | 03:37 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
what he said. just build a box, cost is no more than 35 dollars. or buy a premade one for 70
Old Nov 21, 2009 | 10:52 PM
boldguy's Avatar
Car: 1992 Z28
The reason is because when it was in a box, it sounded great, but there's no cargo space. How it is right now it's just the opposite. I had to crank the volume on the Amp to get it close to where it was before...
Old Nov 21, 2009 | 11:31 PM
Axle/Gears: Stock
I dont think I follow...where do you have the sub mounted? In the cover?
If so the solution would be to cut the cover in a way that as little air as possible escapes and make sure that the cover isnt bouncing around, but again...different subs need different pressure behind them to sound deep.. thats one thing to try though.
Your best bet would be to find out whats the optimal enclosure size for ur sub and go from there.
But yeah...any sub needs certain amount of pressure behind it to create those low notes,
if the air is scaping somewhere you are definately losing db's right there.
Its happened to me and yeah you have to turn up the volume big time.
Thats why the better sealed a box is,the tighter the bass will be.
I'd either build a small box for ur sub or get some shallow mount ones.
Old Nov 22, 2009 | 12:12 AM
boldguy's Avatar
Car: 1992 Z28
yea i made a lid for the cargo area. They are 12" Kenwoods, (I believe 800W?)... i want to avoid the box if possible...
Old Nov 22, 2009 | 12:28 AM
Stephen's Avatar
Car: 87 GTA
Chances are, the area that is now acting as "the box", has way to much space, compared to the space that the box was giving them.
Old Nov 22, 2009 | 07:28 PM
boldguy's Avatar
Car: 1992 Z28
so whats the disadvantage of having "not enough space" as in the bowl idea?
BRoss99
Aug 10, 2025 05:08 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
midias
Aug 15, 2015 05:07 PM
mustangman65_79
Aug 13, 2015 07:36 AM
mx127
Aug 10, 2015 08:13 AM
