Will this work?
Old Mar 11, 2010 | 09:43 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Will this work?
PLUS
PLUS
EQUALS
Old Mar 11, 2010 | 10:07 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: Will this work?
1.-Thats a line out converter....not a line in.... sound comes out from those rca's..u cant send sound in
2.-the 2nd picture is a 3.5mm splitter..U'd need a 3.5 to RCA adapter
what I'm tryin to say is....no it wont work.....
Old Mar 11, 2010 | 10:11 PM
Axle/Gears: Stock
Re: Will this work?
P.s some members in the forum have an adapter u can hardwire the way u wanna do it...maybe someone can chime in and shed some light on thiss.....
Old Mar 11, 2010 | 10:14 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Will this work?
I dont mean exactly this stuff, just something like this, I'm getting tired of my FM transmitter.
Old Mar 11, 2010 | 10:29 PM
Axle/Gears: Stock
Re: Will this work?
In that case...if u get something completely different yes it will work lol
Old Mar 11, 2010 | 10:31 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Will this work?
Well all I need is some type of adapter that would go into the back of the radio and the wiring harness of the radio and then a cable to plug into my Zune.
So that would work?
Would it just cut to the Zune when the radio was off and the Zune was on, and vice versa?
Old Mar 11, 2010 | 10:36 PM
Axle/Gears: Stock
Re: Will this work?
what u need should be in there somewhere....
http://www.installer.com/aux/
i THINK its this one......Im not sure...
http://www.installer.com/item/displa...hp?it=AAI-GM24
Old Mar 11, 2010 | 10:41 PM
Axle/Gears: Stock
Re: Will this work?
Ok I looked it up and while u cant hardwire the line in....u can get a FM modulator...(not a FM transmitter) while it might be possible to solder an aux in into the board of ur radio.....this thing plugs into ur factory unit's antenna and gives u better quality than a fm transmitter:
http://www.installer.com/item/displa...php?it=FMM-100
Old Mar 11, 2010 | 10:53 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Will this work?
Ok so I get that, how do I install it exactly?
And then once thats in, all I have to do is hook my Zune up and I'll be good to go?
Old Mar 11, 2010 | 11:17 PM
Axle/Gears: Stock
Re: Will this work?
the way I see it.....you install the yellow wire to hot...the red to ignition....ground to ground....antenna plug to the antena opening in the back lol,then all you'd need is a 3.5mm to rca cable.
Old Mar 11, 2010 | 11:35 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Will this work?
What do you mean yellow to hot and red to ignition? I know what a ground is, and the antenna is pretty simple, but more than that and I don't know, haha.
Old Mar 12, 2010 | 12:01 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: Will this work?
Yellow would have to go to a 12 v constant should be orange on the cars harness and red would go to the yellow wire on the cars harness for ignition
this link may help you it sure helped me when I had to wire my stereo up to a hack job http://www.iroczone.com/images/wiring/1988wiringb.gif
Old Mar 12, 2010 | 10:51 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Will this work?
Thank you!
Old Mar 13, 2010 | 08:15 AM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: Will this work?
If you have a cassette radio, just buy a cassette adapter to use the player.
Old Mar 13, 2010 | 09:50 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Will this work?
Nope! lol
I want to keep this radio, only about a thousand of them were made for my model year.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
