Isolator unit
Old Apr 15, 2010 | 02:53 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Isolator unit
Well, Im in the market for a new isolator unit. Im looking for any reccomendations on a good one.
Im running a 140amp alternator and two deep cycle marine batteries.
with 3 old school harmon/kardon amps, 1200 watts total.
What have you guys here had luck with?
Old Apr 15, 2010 | 10:35 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Isolator unit
You'll be fine with something like these. Look in the Group 2 applications if you have the CS130/CS144 alternator.
http://www.donrowe.com/battery_isolator/isolator.html
I have one similar by Phoenix Gold, when they were still selling them, 160 amp IIRC, maybe less (they didn't make them, just put their name on them). It does my 1400 watt system just fine. My CS130 alternator has been rewound to output 144 amps.
Another place to check for isolator/combiners that was recommended to me when I thought about going that route...
http://www.hellroaring.com/battery1.php
Old Apr 16, 2010 | 11:07 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Isolator unit
This might suit your needs.
http://www.woofersetc.com/p5297/SGP3...y-Isolator.htm
Old Apr 17, 2010 | 02:19 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Isolator unit
Originally Posted by The Project
i was about to suggest that one too. i wonder why their is such a huge gap in price with the stinger compared to the rest?
Old May 4, 2010 | 04:48 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Re: Isolator unit
Looks like the stinger one is a relay isolator, the others are diode isolators.
Old May 5, 2010 | 12:01 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Isolator unit
what are the differences? is one better than the other?
Old Jun 2, 2010 | 10:00 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: Isolator unit
Relay isolator is a physical disconnection. Diode isolation relys on the one way flow properties of the diodes to do the job. Diodes can leak backwards...hence they're cheaper.
Old Jun 3, 2010 | 01:35 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: Isolator unit
Well I wound up getting a free relay isolator from a buddy at work, brand new.
Installed it only to find out i also had a bad battery.
Replaced battery, both are charging fine now.
This car is driving me crazy i swear!!!! At first whenever the subs would hit (after installing the isolator) i could watch the volt guage drop more every time, after replacing the battery the deck turns on, the amps turn on but no sound comes out!
thanks for all the help everyone, im starting to get frustrated
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
