Please help me sort out the Vert
Old Apr 30, 2010 | 01:17 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hi guys so here goes (I'm new to this so bear with me )-
I have a Sony head unit with 4 channels but NO RCA out.
Have Alpine- SXE-4625s 2 Way 150w Coaxial Speakers (Front)
Impedance: 4Ohm
Frequency Response: 90Hz-20kHz
20w RMS / 150w Peak
Stock rear speakers
Kenwood KAC-819 2 Channel Amp
12" Kenwood Sub
Question is this- how to wire it up?
I could keep the fronts run off the head unit
Run a RCA converter off my rear channel head unit speaker wires.
Run the sub off the amp
But what about the rear speakers? I know they are stock but I could always upgrade. Just don't know how to make this work.
Or could I run all four car speakers off the front 2 channels from the head unit, convert the rear channels to RCA and just run the amp from that?
Really appreciate any guidance on this.
Thanks,
Felix
Old Apr 30, 2010 | 03:04 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Please help me sort out the Vert
you can still run the rears with the converter hooked up
use this http://cgi.ebay.com/ebaymotors/Chevy...item35a836c998
Old Apr 30, 2010 | 08:55 PM
birshking's Avatar
Car: 1985 camaro iroc z-28
Engine: 5.7L
that kit is for a factory radio that kit may not be what he wants. but close. use a in-line level converter. how it works is by using the wires that are powering the rear speakers and convert it to rca so you can use it for the amp input. so instead of getting the signal from the rear of the deck, it gets it from the rear speakers by tapping in the line. if you tap in the rear speakers you still keep the rears and have a amp input
these in-line converters cost less than 20.00
Old Apr 30, 2010 | 09:26 PM
birshking's Avatar
Engine: 5.7L
Old May 1, 2010 | 03:05 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Guys- that is awesomeness. Even a diagram!
You guys rule.
Old May 1, 2010 | 03:12 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Will this do the job?
http://cgi.ebay.co.uk/Fli-FLLC-Hi-Lo...item35a545fb07
Old May 1, 2010 | 08:39 AM
91RSinNS's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
Yep, thats it. Shop around locally tho...thats 15 pounds, plus shipping & currency conversion. Gonna be gettin' on for $30 by the time its at your door. My local audio supply place sells the line level conversions for under $25.
Old May 1, 2010 | 02:40 PM
birshking's Avatar
Engine: 5.7L
sorry didn't realize you were over seas. i thought you were in the u.s. i got mine from a bestbuy, i guess you could look up ebay for hi/low level converters.
Old May 2, 2010 | 03:18 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Yeah that link is for the Uk which is where I am living. Many thanks guys.
InfernalVortex
Apr 20, 2021 11:31 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
okfoz
Oct 13, 2015 02:19 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
