8inch speaker set ups ?
Old Nov 21, 2011 | 01:37 PM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
hey guys i'm building another camaro and I'm not going to be able to put as big of a system in it this time was wondering if any one had some pics of space saving systems for the hatch. i dont want to hide it as i like seeing the system but id like to keep it small enough for the room. i was thinking a single 8inch i'm just looking for a little bass to support the tunes. i'm going to have twin nitrous tanks and the battery in the hatch so any suggestions would be great.
thanks
Old Nov 21, 2011 | 11:37 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Re: 8inch speaker set ups ?
I saw somebody that did two 10 inch shallow mounts on rear part of the hatch itself. Don't have any pics of it though, maybe somebody else knows where to get them? Otherwise enclosures can also be done where the spare tire and glovebox are located. Just depends upon where you plan on putting stuff and how creative you want to get with building material because you can do some pretty crazy stuff with fiberglass as opposed to regular mdf
Old Nov 23, 2011 | 07:29 AM
89fbrestor's Avatar
thanks for the input joe.
Old Nov 23, 2011 | 09:22 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you're good with a saw, you can get box with about a cu ft of airspace out of the lower half of the well, just enough for most 12" subs. a single 10" should fit even easier.
the crafty ones get the 8"s into the sail panels, may be one of my future projects...
Old Nov 23, 2011 | 09:29 AM
89fbrestor's Avatar
Hey dan thanks for chiming in you always have good input to offer. can you elaborate a little on what you mean? lower wheel... in the lower portion of the hatch behind the plastic? the 6x9's i'll be happy with i'm going for a really crisp and clear sound this time and just looking for a little thump to help the sound. i would probably have room for a well box but i really want it to look clean back there and not crowded. i thought about putting the battery behind the plastic and just doing a single 8 or 10 in the well and the amp and capacitor on the opposite side and then the nitrous bottles up top behind the seat.
Old Nov 23, 2011 | 09:47 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Here is an old shot of what I did in my last 3rd gen:
The top of the box was flush with the ledges half way down in the well. Still allowed for the t-top bag to be used without issue. No hacking involved and hit plenty hard.
the driver side is a good spot for the battery, just make sure you secure and vent it properly. skip on the capacitor; upgrade the "big 3" first. A class-d amp will draw less power than an equivalent A/B, making your charging system a little happier.
Old Nov 23, 2011 | 09:51 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
that was me! or atleast i did 2 shallow 10"s in an mdf box in the hatch well. I made the box top even with the little ledges on either side of the well, rockford fosgate 10" punch shallows. It soudned nice, i cant seem to find pics though Ill look some more
Old Nov 23, 2011 | 09:53 AM
89fbrestor's Avatar
sounds good. thats kinda what i was thinking on. i like when they sink the amp into the box so i might do something along those lines as well. any suggestions on a nice speaker for this set up. $ is not a worry as i'm not putting a monster system in this thing so i think i could go a little better for a single speaker. my goal is something that will support the factor component set up(new speakers of coarse) plus i'm adding 5inch door speakers.
Old Nov 23, 2011 | 09:55 AM
89fbrestor's Avatar
that would be cool i'm fishing for nice ideas. this car is going to be insane and id love for system to equally give the wow factor as the rest of the car i hope will be
Old Nov 25, 2011 | 01:45 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
If you want to keep the hatch area clear for batteries, etc.......
Old Nov 25, 2011 | 10:12 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i had a single 10 in the lower part of the well and it hit pretty good. now it still hits hard with the 2 10's in there, but i need more airspace and plan on either building something like the abbove for both sides, or the standard full well box.
Old Nov 25, 2011 | 03:43 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I did that with my 89. I sealed up the area as best as I could with expanding foam and deadened with a Dynamat and an equivalent. I'm sealed along the had liner - to - sail panel junction, all the holes in by the floor are sealed but accessible, I sealed the door jamb vent and the opening to the hatch area is sealed up. I have 8" Kenwood eXcelon woofers in the sails, I'm only supplying them 60 watts RMS apiece but they're capable of 150 watts RMS each. I might put a better amp in later, but they sound really good for now.
Old Nov 25, 2011 | 04:46 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
8inch in the sails are my personal fav, looks good Al
Old Nov 26, 2011 | 06:49 AM
89fbrestor's Avatar
sold!!!!! now that sharp. the 8's in the sail panels would be cool but the 6x9's are loud enough for me. i love the the way this set up looks and i think i'll go this route. what did you use for your box material? thanks for the input guys this stuff rocks.
Old Nov 26, 2011 | 04:05 PM
Car: 89 IROC
It's not my box, bit if memory serves, 1/2" mdf was used.
You could get creative, build a glove box and add a door.
Maybe secure the door with some velcro.
tcflint
Sep 14, 2015 04:55 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89lsc
Aug 14, 2015 04:58 PM
