What size power wire to run in an 850W amp?
Old Jul 2, 2012 | 03:03 PM
mrrman's Avatar
I just picked up an Alpine MRV-F450: 850W unit. Is 8 guage wire enough or should I use 4 gauge for power. The amp will have a 50A fuse inline with it. Thanks
Do I need a capacitor to? If so what kind/type?
Old Jul 2, 2012 | 03:09 PM
the209bnr's Avatar
Car: 1984 Pontiac Trans Am
Engine: L69
Transmission: THM-700R4
Axle/Gears: 3.73 Posi
Re: What size power wire to run in an 850W amp?
I'd say go with the 4 guage wire, and def use a capacitor. Unless you want to have a 2nd battery.
Old Jul 2, 2012 | 03:24 PM
mrrman's Avatar
With this formual would 1F be enough? One Farad of capacitance per 1,000 watts of power with a minimum of one Farad.
Old Jul 2, 2012 | 04:13 PM
86TransAmAZ's Avatar
Car: 1986 Pontiac TransAm
Engine: 5.0 305
Transmission: Automatic transmission
I'm not no expert but 4 gauge would do you pretty good I think . I have a 750watt JBL amp and I got 4gauge wires
Old Jul 2, 2012 | 06:36 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Voltage X Amps = Watts
Or what you want to know,
Watts divided by voltage = Amps
850 divided by 12 volts = 70.83333333 Amps
Wire being what it is and the usage in your case, by gauge 12 gauge = 20 amps
10 = 30
8 = 40
6 = 60
4 = 80
As far as wire for this purpose you want a fine stranded 4 gauge wire like as in a welding cable or heavy duty jumper cable. I would also solder the connectors rather than just crimp them.
Old Jul 3, 2012 | 08:32 AM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
You'd also want to keep the distance in mind as well. I've enclosed a chart for reference (on this or other projects).
Old Jul 5, 2012 | 02:00 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
never hurts to run bigger than u need right now you never know if u might upgrade!!! ive also found all wire is not created equal cheep brand 4 gague is smaller then rockford fosgate 4g wire i usualy go for big and cheep like my...... ahhh thats another discussion
Old Jul 6, 2012 | 04:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Not trying to step on anyone's toes, but a good formula for finding what ampere fuse to use is Wattage / Voltage / Amplifier Efficiency.
As a rule of thumb, Class AB amps are ~65% efficient. Class D ~80%
I normally use 13.6 volt DC because a fully charged battery will cause the alternator to put out about that voltage. Even if the alt is putting out max voltage, it's not uncommon to see ~1 volt drop with hard bass notes.
850 watts RMS / 13.6 volts = 62.5 amperes
62.5 amperes / .65 = ~96 amperes (Class AB)
62.5 amperes / .80 = ~78 amperes (Class D)
That's why Class D amps are more desirable for bass. They make more wattage with any given amperage.
BRoss99
Aug 10, 2025 05:08 PM
RazorN8
Jan 7, 2022 11:44 AM
ZsTransAm
Aug 11, 2015 07:30 PM
knight72
Aug 10, 2015 09:32 PM
