4x9 to 6x9 dash
Old Nov 12, 2012 | 09:28 PM
zacw4328's Avatar
Car: 92 Camaro RS
Engine: 5.0 305 TBI
4x9 to 6x9 dash
I am wanting to put aftermarket speakers in my 91 Camaro RS. I looked up the dimensions for the speakers, getting the result of the speakers under the dash being 4x9. I read that getting aftermarket 4x9 speakers is a waste because speakers that size are not really that great.
So I ran across speaker size adapters. I honestly don't really understand how they would work. Can anyone help me out on this? What kind of speakers do y'all have under the dash in your camaro and/or trans am?
Thanks for the help!
Old Nov 12, 2012 | 09:45 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: 4x9 to 6x9 dash
Take the dash off and take a look at where your stock 4x6" speakers are and you'll be able to answer your question of if you can fit 6x9" speakers in there.
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Re: 4x9 to 6x9 dash
They are 4x6's under the dash pad and 6x9's or 5x7's in the rear. The only speakers I know that will swap into the front are 4 inch round speakers.
Here is a good website with free shipping sonicelectronix.com
The 4x6's are not that bad i have sonys in my truck and JVC's in my Trans am. I like the JVC speakers better.
Hop this helps
Old Nov 13, 2012 | 11:09 AM
zacw4328's Avatar
Car: 92 Camaro RS
Engine: 5.0 305 TBI
Re: 4x9 to 6x9 dash
Alright I will do that. Thanks.
Hop this helps
Okay. I'll look around there.
Thanks for the help guys.
Old Dec 3, 2012 | 08:51 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: 4x9 to 6x9 dash
I managed to fit shallow mount 6.5 in the front dash and sound was dramatically better.I used some 1/4 inch thick rubber grommets as a spacer between the dash pad and the speaker so it didnt crush the surround and put screwed the dashpad back on nice and tight.
I originally made 6.5 kick panels but they were big for the components i got and would no longer fit once i converted to a stick car so i had to find an alternative and 4x6 just dont cut it for me.
Old Dec 4, 2012 | 08:24 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 4x9 to 6x9 dash
i used pioneer factory size speakers in my 86. couldnt be happier.now my stereo dont go BOOM! BOOM! (im getting old) but with 50 watts per channel its crisp and clean
Old Jan 4, 2013 | 11:57 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Re: 4x9 to 6x9 dash
Hop this helps
5x7's in the back??? where at? all i see is under dash and the ones by the back seats(6x9's)
Old Jan 4, 2013 | 12:06 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
Re: 4x9 to 6x9 dash
The 6x9s in back can swap out with a 5x7. My trans am had 5x7's originally but I swapped in JVC's 6x9's in.
Old Jan 18, 2013 | 10:34 AM
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
Re: 4x9 to 6x9 dash
I dont know if you want to cut into your dash but i did and surface mounted Pioneer 6x9s in. I have a wall with 4 Kicker L5 12s and needed front stage that reflected off the window.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
