Rear mount camera location
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Im adding a back up camera to my system and was wondering where people are mounting them for best results. Pics would be helpful. I purchased a pioneer ND-BC6 to go with the pioneer 1400 dvd player. Wife has been driving my camaro and was complaining about the dark tint when she backs up so I figured this might help a little. Any help would be grateful, Thanks guys
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: Rear mount camera location
Can mount under the trim or mount on plate. Higher is better.
Car: 1991 Trans Am convertible
I have the same Pioneer hu. I love it. I started installing the camera but didnt quite finish it yet. Too many car runs to go on right now.
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Mine came with a bracket to mount to the top two holes of the license plate frame.
It seems to work fine there although I do like the third brake light idea.
My third brake is in my spoiler (which is flush mounted) so not sure how it would look there on my car.
Car: 86 IROC Z28
mine as well. i cut the ends off and made a trim hole in the lens of 3rd light and epoxied it in. if you still want the lights to light up you can still have them on each side of the cam. to those behind you they will think you have a light out but who cares when it comes to custom.
you could also look into mounting it inside the top of the glass
Car: 86 IROC Z28
i think there is a year that has the light inside the top of the glass, would make a good fab pod
Car: 85 Camaro
Engine: 454 RamJet
I like the third light mount,bet it has good vision. My car doesnt have one inside or out although I tried mounting iton the inside roof, right on the edge of the glass but The rear window defroster lines partially blocked the vision. I ended mounting it on the bottom of the 91-92 rear spoiler im currently running. Vision is good and you cant see it unless you look for it.
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
On my 86 I put my camera into the third brake light up on the back glass. I have a wall of subs so I needed a way to get past the huge blind spot. I wired it to the acc so its on when the cars on and routed to a 7" screen under the center vents on the dash. If you want it to come on only when in reverse then tap the back up wire in the loom under your cubby compartment left side rear.
Attachment 252511
Attachment 252512
Attachment 252513
Attachment 252511
Attachment 252512
Attachment 252513
Car: 86 IROC Z28
Some like it, some hate it... I love it.
Tho now that you mention it, they do look like dog bowls, thanks
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
What is the dimensions of the camera.. I am more wondering how long is the camera before the wires come out.
Car: 85 Camaro
Engine: 454 RamJet
I really like the firebird placement. Looks like it belonged there. Just use a power hatch and use the release button on the dash. Very Nice!
Car: 1987 IROC-Z
I was thinking the same thing.. I wouldn't know where to place it on a camaro to make it look factory.
Car: 92 T/A Convertible
Engine: 5.7 (L98)
Transmission: WC T-5
Axle/Gears: 3.27 LSD
just in case the battery died, fabricated a pull cable system to open my trunk. as for the night vision. it works really good with the backup lights but if the car behind you has his headlights on your screwed!
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I'd like to do something like this but I'm not sure where I could put one. Mine's a Camaro 'vert with the 3rd stop light in the spoiler. I'm not sure how I'd run the wiring.
Car: 1991 Firebird Trans Am
Engine: 5.0L 305 TPI
Transmission: 4S Auto
Car: 1987 IROC-Z
I like this as it doesn't require drilling additional holes in the body.. The only problem I can foresee using this on a camaro though, is the rear License plate flips downward so you can't put it on the top unless you don't want to use your rear key ever again and if you put it on the bottom, it will rub on top of the rear bumper..
Engine: 305 TBI
And as mine is a convertible, I do not have a trunk release button inside the car and have to use my key to get into the trunk.
Car: 86 IROC Z28
On the camaro you can put it on the top of the plate, just run the wire between L plate and back plate down to the hinge and go left inside the bumper under the left taillight to the loom grommet, drill a hole with new grommet and enter under the lock box and rout down the drivers side. This was its first location before going to the third b light, I wasnt getting enough view with it being a constant cam.
You can prob tap the loom grommet if you dont want to drill.
Car: 86IROC,85Z28,70 Chevelle,92 Mustang
Engine: 305,305,350,5.0
Transmission: 700 R, 350,5-Speed
How did you run the wires inside the car from high mount third brake light on the 86?
Car: 86 IROC Z28
First time i wired in the camera it was a wireless vid unit. The cam only had pos and neg wires, so i disconnected the brake light lead behind the plastic that covers the trunk latch and connected an acc lead to it. The 3rd b light and defrost ground through the struts. Then wired the pos and neg to the light terminals. Now im wanting to grow some ***** and drill and grommet the glass under the pod with a glass bit so i can run a standard cam(better resolution) and reconnect the b light with led to match my led tail light setup.
colton_carlson
Mar 8, 2019 12:21 PM
but I was going to mount to the top of the plate
