Kick panel speakers install
Old Jun 24, 2013 | 09:01 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
To fix the unbalanced sound front to back that these cars have, I added a set of kick panel speakers. The speakers I used are Pioneer 6.5” 3-way with a mounting depth of 1-3/4”. A hole was cut in the plastic panels to mount the speakers. There is an access hole in the frame for the door hinges that was slightly enlarged to allow the speaker magnets to sit inside. This allows the panels to be reinstalled without sticking out any further and sacrificing leg room. Now, the sound is equally balanced front to back.
Old Jun 24, 2013 | 01:52 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: Kick panel speakers install
Very nice I did something similiar
Old Jun 24, 2013 | 06:08 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
looks like the are very recessed in their holes. How much of a cut did you do? Could you detail exactly how you did this? I'd rather just cut a hole in mine than buy those logic ones that stick out like a sore thumb.. thnx!
Old Jun 25, 2013 | 08:53 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yeah, I saw the q-form kick panels too and was not a fan.
First I used a sawzall to open the hinge access hole slightly for the speaker magnet to fit in.
Next, I cut a 5" hole in the plastic panel for the 6.5" speaker. The grill OD was larger, so I also had to carefully cut the raised sections of the panel. I only cut small amounts at a time until the grill sat flush.
The last step was using black silicone to seal up the entire backside of the panel.
Old Jun 25, 2013 | 09:15 AM
wow! Cool stuff! How did you run the speaker wiring to that location? I'm really not savvy in wiring sorry if it's a basic question.
Old Jun 25, 2013 | 09:40 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
The wiring is ran under the carpet to the head unit and spliced in with the dash speakers.
Old Jun 25, 2013 | 10:40 AM
So ur running dash speakers AND these kick panel speakers?
Old Jun 25, 2013 | 02:54 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yeah, I currently have a Dual XHD6425 head unit, Auto Bahn 2-way 4x6's in the dash, Pioneer 3-way 6.5" TS-A1675R kick panels, Pioneer 4-way 6x9's in the rear sail panels, and a Pioneer GM7300M mono amp powering a Pioneer TS-W305DVC 12" sub in the trunk well.
Old Jun 25, 2013 | 04:27 PM
if I run 6.5" in the kick panels, 4x6 in the dash, and 6x9's in the sail panels, but no subs, do I need an amp to power all of that?
Old Jun 26, 2013 | 11:01 AM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
^ I would. Otherwise all 6 speakers are gonna be sharing the small amount of power that your headunit puts out. It will sound a lot louder and a lot clearer. Also it's less likely to distort and blow your speakers at a high volume.
I just put in a second amp for my 4x6s and 6x9s and it sounds way better. And it's just some cheap amp that someone gave me. If I was to do it again, I would have got that amp before I put my subs in. Next car I get, I'm definitely amping the mids and tweeters before I even think about a sub.
Old Sep 27, 2023 | 07:19 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
How do you expect people to focus on the pods you're making w that mint lunchbox in the background of all the pics? That was probably a childhood dream of 90% of the people on this site.
Sorry, do want to take away from the good work on the pods, they look really cool.
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Reddeath210
Oct 6, 2015 08:20 AM
fasteddi
Sep 2, 2015 10:29 AM
