Speaker suggestions
Old Sep 3, 2013 | 05:21 PM
Bruce91RS's Avatar
Speaker suggestions
My buddy gave me his Pioneer head unit (DEH-P5000UB) and amp (GM-6500F) Amp puts out 60 Watts per channel if I use it as a four way or 180 if I use it as a two way. Any stock size front and rear or just rear speaker suggestions would be appreciated. Thanks
Old Sep 3, 2013 | 06:01 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Speaker suggestions
I currently have 6 x9s Infinity in sail panels & they rock great. I have 4 x6 sClarion in dash they are weakazz. I will be adding kick panels soon w/ pioneer or infinity depending on what I can get to fit. Good luck, just installed sound deadener & it makes huge difference overall
Old Sep 3, 2013 | 06:07 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I added Infinity speakers at the dash and in the sail panels to my exisiting Bose system. They are much clearer and better sounding than the Bose. then again, the Bose speakers are over 25 years old.
Old Sep 4, 2013 | 10:01 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
over hyped, you never see any bose anything talked about by people who really know audio
i like polk audio stuff myself but there are a number of brands that are on par with these.
Old Sep 4, 2013 | 11:05 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
i bought a set of alpine's(front and rear) from a buddy of mine, i believe they are the type S, been using them in combination with my crappy walmart pioneer head for 6 years now, still sounds great
Old Sep 4, 2013 | 11:31 AM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Also agree 100% on Polk. MB Quart is another good one that Im currently using. Infinity is a bit over-priced in my opinion, but still sound great.
Old Sep 4, 2013 | 11:39 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Overhype is something that pretty much everyone does. Best thing to do is to actually go to a shop and listen to different brands of speakers as we all have different tastes and needs.
Old Sep 4, 2013 | 11:42 AM
MY87LT's Avatar
Car: 1987 Camaro LT
And yes, they were pricy.
Old Sep 4, 2013 | 09:08 PM
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
Jl audio hands down. Yes the cost a little more but well worth the money. I will be using 6 1/2 c2 setup in the door panels and either another set in the rear or the c2 6x9s there. This will company 2 jlw3s in the hatch. I have this same setup in my blazer for the past 2 years and its crisp and clean. People can't believe the sound that comes from them. They are also powered by jl amps.
Old Sep 4, 2013 | 11:28 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
I'm using JBL's and push them to the limit all the time.. they get my vote.
Stone
Old Sep 5, 2013 | 07:36 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
thats what i mean by a number of brands, so i agree go listen to them see what sounds best with the music you listen to. shops dont normally have the best prices though. one of the online places are normally way better to buy stuff from.
Old Sep 5, 2013 | 08:46 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I build custom stereo here for a soon to be release product and have used JBL, Pioneer, Alpine, Rockford,Kicker, Hertz audio in 3",4"6" size ranges all medium to hi end models.
I have used alpine amps for price/value,perf but recently switched to tripath class T amps for cost (not for car applications) BUT I have used a tripath to amp my center channel in my infiniti dirt cheap clean and small.
For speakers hands down my best value to perf. are the Hertz. They really hit with small space but the highs are the best I have heard. They are 4 ohm but really around 3.1 ohm and are very efficient at 93dbl.
Similiar in price to JBL but usually cheaper if you shop. I like them better get compliments on th fidelity.
I think the pioneers are great cheap speakers with above average sound, always bright with good punch. I like them better then the kickers usally unless I want more bass or volume. The kickers are durable and can be beat up and usually have loud bass low distortion but are muddy on highs.
Rockfords are good all around too but Hertz are just better.
I did try the vifa tweeters too, supposedly the best. I got mid ranges ones and my hertz were way better IMHO
http://www.hertzaudiovideo.com/default_en.htm
Old Sep 7, 2013 | 03:07 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
i ran Vifa mids in my T/A with Pioneer soft tweets in the dash. Sounded great powered by the Pioneer HU.
Currently have Hertz MLK165's ready to go into my IROC as soon as I save up for a decent amp.
http://www.woofersetc.com/p-9607-mlk...nt-system.aspx
Old Sep 9, 2013 | 04:46 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Don't forget the tight fight on the left dash speaker too. I had to cut some of the foam from my dash pad due to the size of the magnet on the speaker.
Old Sep 10, 2013 | 06:23 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
my polk db461's fit with no trimming, just barely.
Old Sep 11, 2013 | 03:50 PM
1986 305 RS's Avatar
Car: 1986 Sport Coupe
Engine: 305 V-8 670 cfm Holley st avenger
Axle/Gears: 13-42
I dont know about altec lancings today I know I spelled that wrong but anyway I had a pair from the early 90s that hit and used to sound so good I put them in a ported home made box slightly bigger that old school home speaker boxes.....I miss them
Old Sep 16, 2013 | 08:55 AM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
How was the sound stage with the BOSE setup? Have you ever been able to compare it with a car that wasn't equipped with it?
Old Sep 16, 2013 | 01:40 PM
MY87LT's Avatar
Car: 1987 Camaro LT
The Bose system was good. Four speakers were way too little for me. The hook up was very straight forward. Front left dash speaker hooked up to the left Bose kick panel speaker and pretty much the same for the rest of them.
I have been in Iroc's with the premium sound with the equalizer radios. There was some difference. Bose was a bit more clear.
Old Jan 1, 2014 | 09:35 AM
"Shroom"'s Avatar
"No highs no lows-it HAS to be bose.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
