amp fuse keeps blowing?
Old 12-31-2013, 04:32 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
ok so i got my new pyle red label subs in and ive wired everything in with a brand new wireing kit everything is wired up properly but wheni turn the car on the amp comes on till the head unit starts up which takes a few seconds. and every time the head unit kicks in the fuse in the amp blows someone help me please?
Old 01-03-2014, 03:08 AM
Sinfulrelations's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Is it a new amp? Sounds like the amp has a short.
Old 01-03-2014, 03:27 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: amp fuse keeps blowing?
try to turn on the amp without the head unit ... as in run a jumper from the main power to the switched power ... to rule out the headunit as the trouble ... and post a pic of the wiring on the amp, if you can
Old 01-03-2014, 08:52 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
It sounds like you have a weak ground on the amp. Make sure your ground is at least one gauge larger than your power. Also, make sure you don't have even a single strand of your remote turn on feed touching the amp body or any other wires at the amp.
Old 01-03-2014, 09:52 AM
mikey8494's Avatar
Axle/Gears: stock
its a realy old amp that sat in the carand the po treated it like **** im gona get a new one its an old school amp anyway
Old 01-03-2014, 10:32 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I had a similar problem once in my 84 & turned out the cig lighter was pushed all the way in. Once i pulled the cig lighter out a bit so it wasn't constantly "running" no problems. I think the fuse that kept blowing was #20....good luck
Old 01-03-2014, 05:37 PM
mikey8494's Avatar
Axle/Gears: stock
laker the fuse that was blowing was the fuse built into my amplifier to my subs i got a new 650 watt max 4 channel amp today gona have it installed and hooked up to my 2 10 inch 600 watt max single voice coil pyle red lable subs
Old 01-03-2014, 06:31 PM
cdoyle's Avatar
I would try unhooking the subs, does the amp still turn off?
If not, then verify how the subs are wired.
If it does still blow the fuse with the subs disconnected, sounds like the amp is shot.
Old 01-03-2014, 07:15 PM
mikey8494's Avatar
Axle/Gears: stock
when it blew the subs wernt even in the box yet
Old 01-03-2014, 07:41 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
What?
I don't know how you get a "weak ground" but a poor ground, would not allow a lot of current to flow, and not likely enough to blow a fuse, unless it was like a .5A fuse, or so, at which point just the amp turning on, even with a solid ground would blow the fuse. There's no need to mix power and ground cable sizes, there is equal current flowing on both the positive and ground wires in a circuit.
It sounds to me, like the amp itself is the problem, especially in a later post where you mentioned that the speakers were not even connected to it. The only other possibility I could see where the amp itself would not be the issue, is if the amp was connected backwards, as in positive wire to the ground input and the ground wire to the positive, but that would likely blow the fuse as soon as you connected it, not after the headunit turned on, due to the reverse polarity protection diodes built into most automotive amplifiers.
Old 01-03-2014, 08:46 PM
Lakerman62's Avatar
Sorry MisRead It, Good luck
Old 01-03-2014, 09:27 PM
mikey8494's Avatar
Axle/Gears: stock
yea six the amp is fried i got a new amp so im gona have it hooked up soon and ill be thumping in no time
Old 01-03-2014, 11:47 PM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
What kind of amp is it?
Old 01-04-2014, 12:04 PM
mikey8494's Avatar
Axle/Gears: stock
i think its an audio teck 350 watt max 4 channel amp
Old 02-08-2014, 12:11 PM
Jonesyfxr's Avatar
Originally Posted by Six_Shooter
What?
I used to run a very prosperous car audio shop up here in Buffalo. I now wire limos, hot rods, drag cars and emergency vehicles. I have been to Audio Control's, MTX's and Rockford Fosgate's wiring schools. Grounds are everything in a 12 volt system.
Here's something to try. Disconnect just your ground wire, then put your DVM inline to compete the circuit. Read your meter and let me know what it says.
Old 02-08-2014, 06:11 PM
mikey8494's Avatar
Axle/Gears: stock
dontworry i got a new amp the old amp was fried now the new amp wants to stay on when the car is off which is weird its draining the battery
Old 02-09-2014, 09:05 AM
Jonesyfxr's Avatar
What wire are you using to turn the amp on at the radio?
You should be using the blue wire from the radio. It's usually labeled remote turn on or amp turn on.
Old 02-09-2014, 01:40 PM
mikey8494's Avatar
Axle/Gears: stock
yep thats what im using i wired a brand new remote wire to the radio remote
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
SRKLEGIN
10-03-2015 10:11 PM
Fanatic1074
10-02-2015 03:47 PM
raymondandretti
09-27-2015 06:43 PM
Quick Reply: amp fuse keeps blowing?
