i need amp help.....
Old Oct 25, 2000 | 12:53 AM
82taGODD's Avatar
my front 6.5 components say they can handle 150 watts. so can anyone tell me what kind of amp i should put into those?? should i get an amp that has 150 watts per channel or something less or more?? ive never dealt with amps before can someone help me. thanks.
Old Oct 25, 2000 | 01:22 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
150 watts max or RMS? A 30-50 watt RMS per channel amp should be fine. Generally speaking, the big power needs to goto the subs. Mids and tweets require little power in comparison.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Oct 25, 2000 | 03:02 AM
daniel dekay's Avatar
9 times outa 10, 150 watts means max power, so i figure 75 watts rms. a 30-50 watt "rated" amp will work just fine. check out your local stereo shops for the brands then post your findings back here. were always here to lend our 2 cents.
daniel
Old Oct 25, 2000 | 03:55 AM
82taGODD's Avatar
yea, it said max power. 150 watts max power. so what should i use for that, and a pair of 240 max power 6x9's?? i would like to get one 4 channel amp for those and later throw a sub and a seperate amp in. by the way, what does RMS mean???? thanks
Old Oct 25, 2000 | 08:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
What brand of speakers are these?
A good 4x50 watt Pioneer, kenwood ect. amp will be great for all 4 speakers. A 4x30 Kicker or Rockford would be even better.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 25, 2000 | 01:46 PM
82taGODD's Avatar
they are both pioneer. the fronts are TSC1653 6 1/2 component, and the rear are TSA6999 3 way 6x9's. any suggestions?
Old Oct 25, 2000 | 02:28 PM
Jim85IROC's Avatar
I'd probably suggest the pioneer 30x4 or maybe a 50x4 amp.
The IROC Homepage
Old Oct 26, 2000 | 11:29 PM
Trnsam87's Avatar
RMS= Root Mean Square its a formula that measures continous AC power.
~~Jaime~~
1987 TransAm
350 sbc
Holley 750 Vac sec
Edelbrock Performer Rpm Heads/Intake/Cam
Flowtech Ceramic Headers
Crane Roller tip Rockers/pushrods
Flowmaster Muffler
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
