Amp Locations
Old Aug 25, 2015 | 05:51 AM
jbates346's Avatar
Amp Locations
I'm looking at finally getting a new subox that sits flush with the rear hatch area, similar to the one seen here. My question is where would you guys put the amps? I hate it when the amps are mounted over the fuel tank, even in a amp rack. Leaning towards trying to have them hidden? Looking for suggestions! Thanks
Old Aug 25, 2015 | 02:11 PM
TheJoeY88's Avatar
Re: Amp Locations
i am about to add a small sub box in the bottom of the rear hatch and i saw someone install a small amp over the passenger side rear wheel well next to the spare tire, nice and hidden which is what i like. With the new Class D amps out there being small they will fit very nicely
Old Aug 29, 2015 | 12:05 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Amp Locations
I put mine in the spare tire well.
Old Aug 29, 2015 | 10:12 AM
cdoyle's Avatar
Re: Amp Locations
I have 2 behind where the storage box thing is/was. I removed the cardboard box, and made a bracket that holds them both.
It worked out great. Don't see them at all
Old Aug 29, 2015 | 10:19 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Amp Locations
Did you do a thread on this? Any photos?
Old Aug 29, 2015 | 02:29 PM
Joe Tag's Avatar
Re: Amp Locations
That's what I did with mine. PDF for measurements to build a box are on here somewhere. Dave, if you can't find them, PM your email and I'll send it to you.
Old Aug 30, 2015 | 09:41 AM
cdoyle's Avatar
Re: Amp Locations
I didn't do a thread on this one.
I'm not at home right now, but I'll look for some pics when I get a chance.
Old Aug 31, 2015 | 12:14 AM
SlowAZ28's Avatar
Car: 1992 Camaro Z28
Engine: 5.7l TPI
Re: Amp Locations
depending on the size of your amp you could also look at going under the passenger seat, running your wires under the carpeting. I'm just not sure in a camaro if you're going to get enough air flow or if your going to kick your amp into protect.
Old Sep 10, 2015 | 06:56 PM
Abubaca's Avatar
Re: Amp Locations
I've thought about doing that as well. Curious to see pics as well.
Old Sep 12, 2015 | 12:17 PM
cdoyle's Avatar
Re: Amp Locations
ah sorry, I forgot about this thread.
I'll try and take some pics of it this weekend. you won't be able to see much though since it's all behind the paneling. which is perfect
Old Sep 13, 2015 | 02:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Amp Locations
I copied almost exactly 87350IROC from his thread.
https://www.thirdgen.org/forums/car-...ml#post4211150
Old Sep 14, 2015 | 09:25 AM
jbates346's Avatar
Re: Amp Locations
The amps don't ever get hot with the cover over them Joe Tag?
Old Sep 14, 2015 | 10:56 AM
Joe Tag's Avatar
Re: Amp Locations
I was a little worried about that too. No issues going into protect mode so far, even on some of our hottest days. Been in for a few months. You PMd for the plans but I'll just quote the post I found it in. My 12s just barely cleared the bottom of the box, but there is enough spare material from a 4x8 sheet to make another top piece and baffles to raise the speakers a little bit.
Originally Posted by spartyon
Emails are getting rediculous for me now about that pdf file. I found that post where I got it so the rest of you looking for the pdf dimensions here it is:
Old Sep 14, 2015 | 10:59 AM
Joe Tag's Avatar
Re: Amp Locations
PDF didn't show in quote. But it's post #62 in this thread:
https://www.thirdgen.org/forums/car-...sub-box-2.html
Old Sep 14, 2015 | 01:16 PM
jbates346's Avatar
Re: Amp Locations
what 12s did you go with? Its hard to find 10s or 12's with the output that I'm looking for in that mounting depth. I'm trying to hit around 30-35hz with my setup. Its challenging but i'm close!
Old Sep 14, 2015 | 04:28 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Re: Amp Locations
Very nice box joe. So many people do a bad job with them. Yours is so flush with the rest of the interior. Great job.
Old Sep 18, 2015 | 03:04 PM
cdoyle's Avatar
Re: Amp Locations
Sorry it took so long, but here is a shot of the amps in the storage box thing. It's hard to get a good picture of it.
I have 2 amps in there. I fab'd up a bracket to hold each one. They've been in there a couple years and so far so good.
Old Sep 22, 2015 | 08:49 PM
kimnach's Avatar
Car: 1988 iroc-z (original owner)
Transmission: 5-speed manual
Re: Amp Locations
I have my amp, receiver, hd radio tuner, and a cap in the spare tire area--these are mounted on an aluminum bracket that I fabricated. there is also a 60A schottky diode and fuse block nearby. (The receiver faceplate is located on an overhead console.)
a mini-itx motherboard, shutdown controller, battery, and ups controller are located (currently out of the vehicle) on a bracket in the rear "glovebox" area.
Attached Thumbnails Amp Locations-m2180008.jpg   Amp Locations-m2180007.jpg   Amp Locations-m2180006.jpg
Old Sep 23, 2015 | 06:35 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Re: Amp Locations
I left space under my box in the rear when I built it for my amps. Worked great they are hidden out of the way.
Old Sep 24, 2015 | 12:44 AM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
Re: Amp Locations
mine is in the spare tire well along with fuses and additional battery
Attached Thumbnails Amp Locations-img_4227-sized.jpg   Amp Locations-img_4202-sized.jpg   Amp Locations-5-4-15-005   Amp Locations-5-4-15-002
Old Oct 26, 2015 | 01:43 PM
dibella989's Avatar
Car: 1988 Trans Am GTA
Transmission: 5-Speed
Axle/Gears: 3:45
Re: Amp Locations
Mudd I really envy your setup, I just put mine in between the two 12s. The only trick is getting an amp strong enough to power your subs while still being small enough to fit in between, I got the Rockford Fosgate R1200-1D. It's 1,200w but mine was actually rated at 1,300w, and still small enough to easily fit. Pictures were taken before I made the wires look all pretty.
Old Oct 30, 2015 | 11:09 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Amp Locations
Some of you could benefit from a "Rear hatch privacy shade" to cover the speakers when you want to. I found a nice one at "Pick N Pull"
= http://www.hawksthirdgenparts.com/ca...r-hatch-shade/
If your not familiar with them , they pull out and connect to the very back of the hatch . So when you open the hatch it moves with the glass . That way when they look through the glass when the hatch is closed all they see is black and the speakers are out of site.
It's not a great photo but you can see it extended and hooked on.
If you don't want to use it you just unhook it an it will roll its self back up.
Old Nov 7, 2015 | 07:56 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Re: Amp Locations
I have one 12" and a slave in a narrow, insulation-filled box, hits good, but I'm about quality... I built a box behind the seat to house the Sony 1200 and 600 watt amps, and I used a computer fan to help with cooling... next is a good cap... amp box not shown here. I cleaned up the wiring since this picture.
IMG 20130103 132937[1]
Old Nov 18, 2015 | 10:47 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Amp Locations
Put mine on a 2ft board covered in matching fabric.Wires running down the center, under the carpet.
Old Nov 18, 2015 | 11:10 PM
TheJoeY88's Avatar
Re: Amp Locations
Saw a member on here post this
there are alot of newer amps that are getting small so it would fit easier there
Old Jun 10, 2020 | 08:27 PM
Rob Matta's Avatar
Car: 87 iROC
Re: Amp Locations
thinking of doing the same amp install wondering if you have any pics? thx Rob
HP52TA
Feb 3, 2018 10:51 PM
gta892000
Sep 16, 2015 12:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
