Speakers "popping"...help!
Old Jan 31, 2001 | 06:32 PM
87 Firebird's Avatar
I've been grappling with putting a GTA stereo in my car for some time now. I finally managed to get ahold of those nifty connectors that plug into them, and as some of you have guessed, the "lock" went on. Since I don't have SW controlls, I can't unlock it. So, I went and got a wiring harness from good ol' Wal-Mart, and reconnected my old deck. Now, I've noticed that whenever I turn the volume up to a listenable level, the speakers make a funny pop on bass hits. These are only the speakers that are connected to my amp. What could it be? The connection is RCA so I couldn't have the ground switched for the signal. Thanks.
Kevin-87 Firebird 2.8 liter A4
!Cat, !Maf, !Air Intake, K&N, Bosch Platinum +4, Blue Streak Cap & Rotor
Performance Rebuild in the planning stages...
Best 0-60 10.26 seconds...for now
Old Jan 31, 2001 | 11:20 PM
9177's Avatar
there is probably to much bass going to them
Old Feb 1, 2001 | 12:05 AM
But that's the funny thing...there isn't. I have bass boost turned OFF on my deck and amp, and the bass level on the amp is 2 or 3 out of 5. This is happening on non-bassy songs, as well. It will be on a bass hit, but the hit shouldn't have been hard enough to make them trip up.
Old Feb 1, 2001 | 08:08 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check the speaker wires...you may have the leads reversed which is causing an inverted phase.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Feb 1, 2001 | 09:14 AM
RGZWS6's Avatar
Definately check and re-check your speaker connections. Just because the colors match dosen't mean that they belong together. I'm not saying you did this, but it is a mistake many people make if they are in a hurry.
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
Old Feb 1, 2001 | 12:01 PM
IROCBandit's Avatar
i had a 10 inch jl that started popping and it turned out to be a blown voice coil. if it sounds like a knocking on the cone, that could be what it is.
Old Feb 1, 2001 | 11:53 PM
Thanks, RGZ, but there are a total of 4 speakers doing this. I simply refuse to believe that all of them got blown at once, or even close together. And pukka, these are RCA hookups. Impossible to get backwards, I believe. Could be a bad connection or two, I suppose. I'll check tomorrow. Thanks to all
Old Feb 2, 2001 | 10:55 AM
RGZWS6's Avatar
AH, I knew this problem sounded familiar. What I have seen in the past, people take a stock radio that does not have pre amp outputs, and splice into an RCA jack. When they plug that RCA into the Amp, it sounds OK at low level, but when you turn it up it completely goes to $hit. If this is what happened......you need an RCA converter. It changes your outputs to pre amp, allowing you to hook a stock radio like the one you have into an amp with RCA inputs. Also, if the amp has inputs for regular speaker wire (screw down type) use those instead and save yourself 15$ on a converter.
Trust me on this one, you have to have an RCA converter to run RCA jacks to an amp from a radio that does not have pre amp outputs. I wouldn't lie!
89 Formula 305 TBI
Old Feb 3, 2001 | 12:49 AM
RGZ, there is a slight problem. This deck isn't the stock one, it is another of mine, that DOES HAVE preamp outputs. They are connected to my amp's preamp inputs. This system has not changed in it's design at all, I have just rewired the deck and am having speaker poppage. Thank you.
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
