Antenna delete/relocation
Old Nov 1, 2018 | 07:49 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Has anyone shaved the antenna and relocated it to inside the passengers side A Pillar? Looking for more of a sleek look and removing it from the fender, but i'm concerned about antenna reception. Are there any other alternatives?
Old Nov 1, 2018 | 08:50 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Antenna delete/relocation
i did this on an '84 TA i used to own. i installed an autoloc hidden antenna on the glass right next to the passenger side a-pillar. you really couldn't see it unless you were looking for it. didn't notice any difference in reception. i plan on doing the same thing to the new '84 TA i'm building.
this was the product i used:
https://www.autoloc.com/catalog/Ante...en-Antenna-Kit
Old Nov 1, 2018 | 09:39 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Plug in the cell phone, go to download music or Pandora, maybe a CD, didn't know people lisito the radio any more?
Old Nov 1, 2018 | 12:40 PM
battmann's Avatar
i'm old - i still like my FM morning talk radio.
Old Nov 1, 2018 | 12:45 PM
GeneralDisorder's Avatar
Most of those radio stations have free streaming if you check out their web site, etc. Broadcast is all moving to digital and internet based...... probably won't be long before radio's have nothing to receive.
GD
Old Nov 1, 2018 | 12:54 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
GD
that gets me too, people putting stock AM/FM radios back in cars and trucks. Eventually is not even going to work when the FCC re-appropriates those frequencies for digital use .
Old Nov 1, 2018 | 12:58 PM
Yep the available freq's are limited and that's exactly what will happen. The Chinese will do a brisk, but short business in short range re-broadcast devices designed to receive digital and transmit analog. Just like what happened to TV.
GD
Old Nov 1, 2018 | 01:40 PM
Car: 86' IROC
Axle/Gears: 3.45
Thats a damn good question. Only one rock station and two alternative rock stations in my area now, The rest is rap crap. Anyway, i don't have any desire to run up the data on my phone for my longer drives. I use Pandora here and there. I work 5 minutes away, so by the time i pull my phone up, set up Pandora, get it connected and playing something i wanna listen too i could have been at work already. Maybe a blue tooth radio is in the future, but i got bigger fish to fry this winter.
Old Dec 29, 2018 | 04:26 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Run the wire inside the car then lay the antenna flat under the dash pad at the windshield. Few guys here have done this and said reception is very good.
Old Dec 29, 2018 | 04:07 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
I bought a cheapo short rubber antenna and buried it under my dash pad. Works so so but I don't really listen to radio (Slacker, Pandora in Camaro and XM in my other vehicles). Might go with the antenna style posted above to see if it works better but really radio is obsolete to me anymore.
Old Jan 2, 2019 | 10:02 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
I got rid of my antenna off of my fender, went with a hidden one from amazon, says to mount it to the windshield, but I put it under the dash on the passenger side, seems to work pretty well.
Old Jan 2, 2019 | 10:56 AM
Car: 86' IROC
Axle/Gears: 3.45
That sounds like a great option. I might go with this.
Thanks for the input guys.
Old Feb 3, 2019 | 08:16 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
I've got that same antenna and have it mounted on the tinted area of my windshield. Its almost invisible. I also use serious xm to.
Old Feb 3, 2019 | 10:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Just go full red-neck !
I can say that,.... it was my car !
Old Feb 5, 2019 | 05:58 PM
BIRD91ZRAG's Avatar
LOL of course the only thing that came in was ignition noise..
Old Feb 5, 2019 | 06:00 PM
Car: 86' IROC
Axle/Gears: 3.45
lmao
Old Mar 12, 2019 | 06:44 PM
MikeP_82's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8
Transmission: Saginaw 4-spd
My car has its antenna relocated to the pass rear fender by my dad when he owned it. The hatch has since snapped it off. I'm probably going to use the windshield mounted one shortly.
alivenkickin29
Feb 2, 2006 01:38 AM
shipfitter_sjd
Dec 19, 2005 10:29 PM
Lime
Aug 31, 2005 09:15 PM
92B4C3051LE
Aug 2, 2003 02:26 AM
RARE-ROC-Z
May 23, 2001 01:06 AM
