New old JVC deck
Old May 24, 2021 | 02:01 PM
theraymondguy's Avatar
New old JVC deck
JVC KS-RX710J
I believe these were meant as factory deck replacement units.
CD / audio jack input
rear out rca
5 band eq
It sounds fantastic compared to the factory deck on stock speakers, better than the early 2000s alpine CD player I had in prior.
Not much for a wiring diagram on the internet, but I’m certain of all but one front speaker “polarity”. It’s nearly match for match on gm wire colour, I put in a patch harness and haven’t cut the oem.
Old May 25, 2021 | 09:35 PM
Sweatlock's Avatar
Re: New old JVC deck
Excellent looking radio/cassette player
Is the backlighting green or amber?
Old May 26, 2021 | 09:09 PM
thainglo's Avatar
That is very cool. I installed a late-90s unit from a Grand Prix because I wanted n to keep the 1.5 DIN and my car came With a busted single DIN aftermarket unit. Looks ok, but not quite period. What you found is plenty nice!
Old May 26, 2021 | 10:37 PM
green sadly. I’d love to have it red to match the gauge cluster or even amber to match the Hvac controls.
Old May 26, 2021 | 10:42 PM
thank you. You can see they really went for the home stereo receiver look.
Unable to leave good enough alone I foolishly pulled out the stock front speakers and swapped in some middle of the road clarion 4” plates… I’ll be re-installing the factory speakers tomorrow. Any thoughts on putting speaker baffles in, I’d like to add a bit of “richness” to the sound and leave it on deck power.
Old May 27, 2021 | 04:52 AM
thainglo's Avatar
Would be tough to have enough space for baffles in the front, I'd think. Unless the plan is to just shove some loose cotton batting in the area. I just had my whole dash out and installed yesterday. With all the venting that runs in that area, it is pretty tight. I have battles (factory installed?) in the rear sail panels and happy with the sound from there.
I also have the factory fronts installed. Sorry to hear the Clarion did not work for you. I considered updating the front speakers while the dash was out and They were so accessible, but decided to just leave them in for current.
Old May 27, 2021 | 01:28 PM
I went down to the local wrecking yard and found this coax set in a ‘01 Cavalier more door. Has an independent tweeter and seems like a bunch more cone stroke (xmax).
I swapped the gaskets off the off the originals, lined the cavities with sound deadener (salvaged from the same cavalier).
With my untuned ear I think they’re a nice upgrade over the stockers.
Old May 27, 2021 | 09:23 PM
NoEmissions84TA's Avatar
Where is the connector for the speaker on the left?
Old May 28, 2021 | 06:30 AM
sharp eye, I harvested it for the new speaker. There isn’t one cut wire on my car.
Old May 28, 2021 | 01:45 PM
Sweatlock's Avatar
Is it possible to get in there and change out the bulb?
Old May 28, 2021 | 02:18 PM
I’m hoping there’s a lens I can remove to turn the backlight to amber.
Old Apr 13, 2025 | 02:43 PM
Phatmatt's Avatar
Car: 1987 Camaro IROC-Z
Engine: SBC 350
No idea if you will see this message, but i got the exact same head unit to install in my car but i'm unable to find what the wires are on it, Do you still have this information?
Old Apr 13, 2025 | 02:48 PM
I did sell this deck to another member. I got the wiring layout by searching other JVC units of the same era, this unit is rare and therefore hard to find information on.
Old Apr 13, 2025 | 02:52 PM
Phatmatt's Avatar
Engine: SBC 350
Wow didn't think i would get a reply this quick, thanks for the info i will check around for other JVC head units and match the wire coloring. Thank you!
KamikazeIroccy
Car Audio
Sep 17, 2011 09:33 PM
Baja B4C1LE
Car Audio
Sep 12, 2011 10:01 PM
defaced
Car Audio
Oct 26, 2008 10:52 PM
FastElectrics
Car Audio
Feb 16, 2004 11:34 PM
jermdm
Car Audio
Sep 26, 2002 12:38 AM
