What omh rating for front & rear speakers
Old Oct 7, 2021 | 06:27 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
What was the ohm rating for factory speakers front & rear? Usually the radio head will have that imprinted on the bottom side of the radio?
I know that in my '72 Buick, the factory speakers were 10 ohm front & rear but 8 ohm worked also which is what I placed in that car. No mixing 8 and 4 ohm unless the two 4 ohm speakers were connected in series. When did 4 ohm speakers become available at GM?
Comments.
Old Oct 7, 2021 | 08:52 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: What omh rating for front & rear speakers
Factory Delco wants 10 ohm in front and 4 ohm in back. However; I've found MANY Delco 10 ohm rear speakers in Camaros over the years..........
One DM165 is for the front and rear left speakers, the other DM165 is for the front and rear right speakers. This way each DM165 drives a 10ohm front speaker, which requires very little power, and a 4 ohm rear speaker.
John in RI's Avatar
Old Oct 8, 2021 | 10:10 AM
72buickgs's Avatar
Car: 1984 Trans AM
If the radio wants 10 ohm speakers as stated on the radio itself, then 4 ohm will destroy the amp. 4 ohm in series is okay but u lose the stereo affect.
Old Dec 10, 2021 | 08:57 PM
vorteciroc's Avatar
Top Answer: 1
There were also 16 Ohm Speakers floating around...
Most of the current Aftermarket Speakers are going to 4 Ohm.
Subwoofers are another story.
mikespeed
Car Audio
Mar 22, 2014 09:17 PM
NeoTath
Car Audio
Jul 3, 2011 10:05 PM
Zrated83
Car Audio
Dec 20, 2003 09:13 PM
fullstackattack
Car Audio
Apr 12, 2003 12:51 AM
Frank88
Car Audio
Feb 17, 2001 11:32 AM
