Not sure if I can use this mid 80's Corvette Delco Boise radio with the 4x6 Kickers installed in a 1984 Camaro? Appreciate you opinoion. Thanks
John in RI
close
- Join DateAug 1999
- LocationRI
- iTrader Positive Feedback100
- iTrader Feedback Score(170)
- Car1984 Camaro Berlinetta
- EngineLT1
- TransmissionT56 6-speed
- Axle/Gears4.11 LS1 Rear End
- Liked:469 Times in 363 Posts
The factory front speakers are almost certainly 10-OHM. The BOSE system uses speakers that are 2-OHM. I would not recommend using the factory 10-OHM speakers with a BOSE system.
There were some GM's that came with a 4-OHM factory 4x6. The 2 I know off the top of my head are the 4x6 used in the factory Firebird 'performance sound' Rear Speaker box ( factory system with the GAIN button/slide) & the 4x6 rear speakers mounted as the rear speakers Fiero with similar 'performance sound' system. While they are not 2-OHM,.......they are better suited for BOSE than factory 10 OHM speakers.
* I have never found a BOSE 4x6 speaker. I used 2 Thirdgen BOSE kick panel speakers as fronts under the dash in my ride. I was able to mount the small round speaker in the factory thirdgen speaker bracket with very minimal modifications. I don't know of any other car that used the same speaker,.... the only place I ever found that type of speaker was in a Thirdgen kick panel.
T.L.
close
- Join DateSep 1999
- LocationColorado USA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'83 Firebird (T/A Clone)
- Engine350 with L-69 components
- Transmission700R-4, 2000 RPM stall converter
- Axle/Gears10-bolt/3.73 ..
- Liked:822 Times in 630 Posts
While we're on the subject, what size are the rear speakers? 6"x9"? Are they 4 ohm? I haven't removed the sail panels to look...
John in RI
close
- Join DateAug 1999
- LocationRI
- EngineLT1
Most Firebirds I've seen have 4-OHM,... Most Camaros I've seen have 10 OHM ------> 6x9's in the back.
Thanks for that info. I found that the 80's Corvette radio won't hook up into an 84 Camaro. So, I've had my factory AM/FM cassette (84) repaired at 150.00 (circuit board). It well hook to the new replaced front 4om Kickers and years ago replaced JBL (probably) 4om rears. Radio being 10om's I believe, I well just need to watch the volume. No finding 10om speakers front or rear.
John in RI
close
- Join DateAug 1999
- LocationRI
- EngineLT1
A Factory Delco is made to run 2-4 and 2-10 OHM speakers. ( each AMP in the radio controls 1-4 and 1-10 OHM speaker. ) Running 4 4-OHM speakers will - over time - kill the head unit. Aftermarket radios are ( mostly) made for running 4-OHM speakers and that's why there are so many 4x6 4-OHMs on the market, but almost no 10-OHMs.
I do have some GM 10-OHM 4x6's if needed. Might need to modify / add screw holes, but they are basically the same speaker as the factory thirdgen. ( these were removed from S10s. )
Thanks for that good info. In over twenty years I have repaired this Delco three times=$550. I may be able to send these 4om 4x6"s back to Amason, maybe. But please give me your price for those two 4x6 10 0mS on the shelf.
Not sure that the private message worked 48377
