Is it possible to install a stock ford CD deck?
Old Feb 17, 2001 | 03:05 AM
SexyCamaro's Avatar
I took the stock camaro deck out and found that the plugs are different from the ford deck,
just wondering if its possible somehow to hook it up.
Also, I unplugged all the wires from the camaro deck and then plugged them all back in,
and now I can barely hear sound, why is this?
Old Feb 25, 2001 | 07:25 PM
myposcamaro's Avatar
why would you want a stock deck in your car? a ford deck none the less? i guess its possible somehow
kev
Old Mar 26, 2001 | 10:42 PM
HrdRockA4305's Avatar
I dunno if anyones still readin this post or not, so i'll just say yes it can be done. Don't call me a crackhead cause of it, but i've put a GM in dash in a dodge before and it worked perfect. It was a stupid thing to do, but theres an explanation, i just doubt anyone really wants to know why the Hell i did it. (wasn't my car just for the record)
88 Base Camaro
305 Auto
All Stock....for now
Old Mar 27, 2001 | 01:37 AM
Omar's Avatar
You can put ANY deck in ANY car, given enough imagination and room. Just remember that Ford likes to use a common ground for all the speakers. Use a wiring harness, and perhaps an electrical diagram from the donor car.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Mar 27, 2001 | 06:44 AM
cbpldc's Avatar
Yes it can be done, as I have done this before. You will need the harness that plugs into the donor radio, a wiring diagram from the Ford, as well as a wiring kit for your car. The wiring kit will just make it easier on you. Find the correct color wire from the back of the donor harness on the radio, and wire it to the corresponding wire on the harness(which will be labeled). The great thing about having the harness is that you can wire it up in your house, and then just plug it in when you get out to your car. Be careful when choosing your Ford radio though. Some of them from Lincolns and upper end fords are pre-amp decks only. Make sure that your radio has built in power, or you won't get squat for sound.
Chris
Old Mar 28, 2001 | 05:16 PM
Kandied91z's Avatar
why would u want to do this i hope you have some dire financial situation.
Old Mar 29, 2001 | 08:16 AM
cbpldc's Avatar
Yeah, I would recommend getting a used Jensen CD player to a Ford unit, just because the Ford radios do not have decent Bass reproduction.
Old Mar 30, 2001 | 02:56 PM
FORD Rustangs -R- Us's Avatar
or go to mr. junkyard and grab the new delco's outa a newer car, like a 98 blazer or so, 96 and up should have it..they have real good bass repro..or atleast can hit hard with stock speakers which is hard to do
Old Apr 2, 2001 | 01:03 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I've done something similar...I wanted to have a stock look to the car(lighting and fit) and still have a decent set of speakers. 4x6 polk plates up front, and kenwood 6x9 rears(the rest is yet to come)....but if you look at my SIG, you'll see, i got a 99 Grand Am GT's indash cd player with equilizer out and with a couple adapters, some light mods to the bracket, made it fit like it came that way in 1986...as soon as i get pics of it, i will post...but it will take a while. It looks great, and the lighting(reddish amber) matches to the rest of the dash. My friend sold it to me out of his 99 Grand Am for 200 bucks...go to the dealer, and they will charge you 900...i know, becusae i called.
1986 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
OTHER RIDE:
1998 C5 6Spd. Corvette
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old Apr 3, 2001 | 10:46 PM
Chris Luongo's Avatar
Phantom, I couldn't agree with you more. I have a Kenwood eXcelon in my car now...but not for long. The factory radios may have a few less features and a little less power, but other than that they are just plain better.
I won't put this aftermarket junk in my car ever again. And I install this aftermarket junk for a living.
Old Apr 4, 2001 | 09:20 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
actually ford's stock units are fairly decent compared to ac delco's,yes you can do anything you want,use a multimeter and/or start a fire and blow fuses....eventually you will figure out what every last one of those wires is for.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bryan623
Aug 10, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
