Speaker box material & thickness
Old Oct 31, 2023 | 07:54 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Would 1/2" Birch suffice for two 10's in a ported enclosure. Trying to keep the weight down a bit from 3/4 MDF
Old Nov 3, 2023 | 02:26 PM
theraymondguy's Avatar
Re: Speaker box material & thickness
Motor force is a concern, are we talking 150W subs or 1500W?
Old Nov 6, 2023 | 08:51 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Twin 150 fosgates with a single channel mono amp
Old Nov 7, 2023 | 07:37 PM
Typical loading, side by each I believe you’d be alright, some bracing between the woofers and in the corners off the box would help to stiffen things up. Having a doubled front plate (married with glue) would be of benefit as well.
Ensure your front and back plate extend over the remaining pieces so that they’re better supported. Remember that the glue is doing all the holding once it’s cured, don’t be shy.
Or be lazy and just put in a baffle board lol.😝
Old Nov 7, 2023 | 08:14 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Lol. I thought about the baffle board but my subs aren't infinite baffle.
Old Nov 12, 2023 | 09:23 PM
Just as all camshafts are turbo camshafts, all subs are infinite baffle.
Old Nov 17, 2023 | 09:54 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I know anyone will work but are they not generally subs with a higher Qt number?
Old Nov 18, 2023 | 08:10 PM
absolutely yes. Sadly modern subs seem to have abandoned Qt in an effort to operate in the smallest enclosure possible. Alpine JL, Kicker, Rockford, Hertz et all.
You might be better served looking at older subs if IB interests you.
Im currently running Alpine SWS10s, Qt = 0.68. Ideally your looking for 0.70 or higher, however isobaric operation will “stiffen” any subwoofer.
Old Nov 18, 2023 | 10:30 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
My Rockford's are 4.9. For a ported enclosure I need 1 cuft per driver. I have two. I have a sealed 3/4 MDF box in there now but it's very heavy and I'm not really liking the sound. Always preferred a ported enclosure over sealed. This is why the IB interested me. The weight reduction.
Old Dec 24, 2023 | 11:45 AM
Wish me luck Edge,
With port and woofer displacement accounted for,
0.85 cu ft 1/2” birch with 3/4” front plate for isobaric clamshell mount. The thinking is that I can get decent cuts off of the bench saw, tight gaps and small dimensions (24x11x9x7) will allow the box to be strong enough. One 3” brace front to back boxes in the woofer and a slim brace along the angled section for a little more surface area (instructions are in the faq, about 70 posts deep).
33 Lbs assembled with 2 10” woofers. The box without the top is 10 Lbs.
Old Jan 6, 2024 | 06:25 AM
91formula_WS6_5's Avatar
Car: 91 Formula WS6
Engine: L98 5.7
Any pics of the finished product?
Old Feb 6, 2024 | 12:00 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Well Sir, you were 100 percent bang on. My "not IB" speakers are now on an open back baffle board and it pounds more than it ever did in the box. A lot more. Crushingly more actually.
SNET Telly
Car Audio
Jan 2, 2011 02:18 AM
popballz
Car Audio
Nov 9, 2007 01:54 AM
Bill/T/D/Y
Car Audio
Nov 28, 2006 07:41 PM
MIKERC
Jul 21, 2006 12:39 PM
