“Trunk Well” subwoofer box build
Old Sep 14, 2024 | 07:51 PM
theraymondguy's Avatar
As per post 67 in the sticky, I give you
The trunk well subwoofer box. 1 cubic foot sealed minus driver displacement. The measurements in the post are excellent, the 18* cut is bang on the money.
I plan to retain the well cover, I’d like to move my amps away from the box. Maybe an amp rack over t top bag, up against the back of the rear seat.
Old Sep 14, 2024 | 08:27 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: “Trunk Well” subwoofer box build
Nice looking subwoofer enclosure.
Old Sep 15, 2024 | 08:38 PM
Managed to get it setup for testing today,
Sub is happy and performing well.
Old Sep 15, 2024 | 09:50 PM
Airwolfe's Avatar
I like the old school Alpine amps. Do you have other old school Alpine equipment installed in the car also? Maybe a Alpine radio with 6 pretty green Chiclet buttons at the bottom right?
Old Sep 16, 2024 | 10:41 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Shouldn't there be some sort of opening for bass reflex somewhere? I'm not too deep into these kinds of builds, but I think the air needs to be able to go somewhere for the sound to travel.
Old Sep 16, 2024 | 01:36 PM
Catbox's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
Looks good in the car for sure.
Old Sep 16, 2024 | 08:16 PM
I can’t do Alpine green and Pontiac red together.
Old Sep 16, 2024 | 08:21 PM
It’s a sealed enclosure, good for sound quality builds (musically accurate). Folks looking for greater spl output would have a ported box.
Old Sep 16, 2024 | 08:24 PM
It fits remarkably well. If a guy were to just do a “baffle board” the measurements in the drawing for the top plate are remarkably accurate. I used a 4.25” hole saw for the rounded edges at the plastic panels, perfect.
Old Sep 16, 2024 | 09:07 PM
Airwolfe's Avatar
This is an acoustic suspension speaker enclosure. A sealed enclosure design that uses the woofer's surround, spider, and the "air spring" inside the box to control and dampen cone motion.
Old Sep 17, 2024 | 03:39 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Thanks for the update, Airwolfe!
I had never heard of that before.
Old Oct 8, 2024 | 01:02 AM
lami's Avatar
Interesting choice going with a sealed box. bet it sounds tight.
Old Oct 13, 2024 | 09:14 AM
Woofer Qts is 0.68 - already a fairly “tight” woofer, which favours sealed vs ported. Generally we would like Qts less than 0.45 for a woofer in a ported enclosure.
Old Nov 23, 2024 | 09:24 AM
Stacked Amps anyone?
Keep your gear stacked under 6.75” and you can close the trunk well cover.
The little guy isn’t part of the install, place holder for DSP.
Old Apr 10, 2025 | 09:34 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
+1 for the above dimensions working well! Fit was as described.
Old Apr 10, 2025 | 10:41 PM
Airwolfe's Avatar
Nice looking subwoofer enclosure you built there.
Old Apr 11, 2025 | 04:54 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
What size sub are you guys using for this short box? 8”, 10”? Definitely not a 12” right.
Old Apr 11, 2025 | 06:43 AM
Car: 91 Z28
Engine: 6.0L LQ9
Thanks! Hoping to finish up all the wiring this weekend.
Mine is a 10" Kenwood Excelon KFC-XW1041.
Old Apr 13, 2025 | 07:32 PM
Mine is a 10” as well. Interior dimensions for the 1/2 well box are right at 1 cu ft. Perfect for an old school single 10” on 300W, you could likely run a new school 12” if you were careful with dimensions and power.
Old Apr 13, 2025 | 07:37 PM
That’s a tight install. Looks great.
Old Apr 13, 2025 | 08:05 PM
Car: 91 Z28
Engine: 6.0L LQ9
Thanks, finished all the wiring this weekend. Ended up upgrading the charge wire off my alternator and added some heavier gauge grounds.
Hits plenty hard for what it is.
Old Apr 16, 2025 | 10:48 AM
Fourth Gen LT-1 battery ground and positive cables are the poor man’s “big three” for cars with passenger side battery.
Upgrades alternator charge wire, chassis ground and provides a 6 gauge accessory wire.
Old Apr 16, 2025 | 11:01 AM
Car: 91 Z28
Engine: 6.0L LQ9
With the LS swap, all of my wiring was upgraded at that time. Just didn't have a big enough charge wire in my mind with the upgraded audio draws.
Old Mar 8, 2026 | 10:43 PM
Well, as it would turn out 10” just wasn’t enough.
I’ve remade the box to fit a 12”. The box will give you right at 1 cu ft sealed which is enough for any efficient driver. The Alpine SWR 1223D is absolutely overkill, an Image Dynamics 12” would work amazing at half the cost.
Old Mar 10, 2026 | 08:40 PM
dannyual320's Avatar
raymond, I'm glad that you posted this about fitting a 12" sub. I've got a 12" Kenwood sub and my plan was to build this same box but I wasn't sure if the 12" cone would physically fit. You confirmed it. I'll be driving it with a JL Audio 5-ch amp.
Old Mar 10, 2026 | 09:27 PM
Nice. You’ll see I mounted to the drivers side, might be tight on passengers side depending on year of your car and woofer. The rear panel does angle forward as it rises.
Old Mar 12, 2026 | 09:21 AM
I'll probably mount my subwoofer to the driver's side as well. The JL Audio amplifier will go on the passenger side.
I've got another set of subwoofer plans where the box seems to be a couple of inches taller than your sub box. The taller box would give me more room both in depth and in upper surface area to mount my 12" Kenwood.
Old Mar 13, 2026 | 11:55 AM
I can’t say that would work out. This box had to rolled into place to fit, there’s no room for additional height - unless the upper section is installed after the fact? I’d like to see a drawing if you have one.
Old Mar 13, 2026 | 06:38 PM
I’ve been cobbling car audio for 3 decades, never did use T nuts. This box is too nice to butcher, well worth the effort (not so sure about $20 CDN in hardware?).
Old Mar 13, 2026 | 11:12 PM
Airwolfe's Avatar
Since you are Canadian did you use Robertson head screws?
We used them all the time from the 80's on up in our cabinet shop. I used them exclusively when building subwoofer enclosures for automobiles and loudspeaker enclosures.
Old Mar 14, 2026 | 12:28 AM
Airwolfe's Avatar
You can build a subwoofer enclosure that sits even with the the flat area behind the rear seatback. I built many of them in the late 1980's to early 2010's
Old Mar 14, 2026 | 08:56 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Agree^^
I used a 1" baffle board w/2 JL free air 12's, carpeted it to match the car's carpet, then dropped it in where the cargo door had been. It ripped, and I could still put luggage under it, and I put "regular cargo" over it (for me, that was skis, mtn bikes, water skis, typical luggage)....so it didn't degrade from the usability of the rear cargo area in a meaningful way.
Old Mar 14, 2026 | 09:05 AM
I'm trying to attach the PDF file here. Hopefully it attaches. It is a file that is attached to post #62 of the sticky, "Dimensions for well sub box."
It appears to be a little taller than your box but I'm really not sure.
File Type: pdf
Old Mar 14, 2026 | 11:12 AM
The pdf came through. It does specify that there will be difficulties getting the box installed near the end of the document, I’d agree. I probably would have built this box instead if it weren’t for my car having the sub well trunk cover, which wouldn’t fit with this box installed.
Old Mar 14, 2026 | 11:33 AM
Raymond, thank you for this information. My car doesn't have the trunk cover so maybe this particular box may be the better choice for me.
Old Mar 15, 2026 | 11:47 AM
No, I’m a clamp & Brad nail guy. At work do however ship our core & warranty claim parts back to the USA with Robertson screws (the pride of Milton, ON. We would’ve won WWII sooner with the Robertson but the English recognized we needed America to win that war & then bought in on the Philips head instead…). The manufacturer keeps asking us to use Torx & we keep shipping crates built with Robertsons lol.
Old Mar 15, 2026 | 11:50 AM
Agree^^
This was super common. I even built one myself just for the sake of interest. It got the job done at a very limited price.
Old Mar 15, 2026 | 11:52 AM
With the latest generation of shallow woofers this would be my go to with a coupe. So much less waisted cable & space going to the trunk well. I’d want the cargo cover for sure though.
Old Mar 15, 2026 | 11:55 AM
I’d go mdf & round off the exterior corners. Too many pieces for a successful birch build, you’ll want to do as much bracing as you can (3/4” mdf trim is cheap & easy to find)) and acrylic latex caulk every seem.
Old Mar 15, 2026 | 12:19 PM
Engine: LT1, L400
Yep. It sure did. Hard to beat...esp for a driver.
Old Mar 15, 2026 | 09:09 PM
I'm planning on using MDF. I do have a router so that should work good for rounding off the exterior corners.
Berlinetta101
Apr 8, 2008 09:08 PM
87TPI350KID
Car Audio
Jul 29, 2006 07:07 PM
EthanH
Car Audio
Apr 1, 2006 07:53 PM
MoJoeVanilla
Car Audio
Jan 6, 2003 08:41 AM
alex13507
Car Audio
Jun 16, 2002 09:36 PM
