sub box
Old May 13, 2001 | 11:27 AM
87firebird's Avatar
sub box
I want to put two 12" subs in the back of my firebird. I'm going to make a box and want to know the best dimensions. Please show me pictures of your sub boxes and tell me the dimensions?? Thanks
Old May 13, 2001 | 04:15 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm not trying to be an *** , but if you've got the skill to build it, you should have the skill to measure for it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 13, 2001 | 07:06 PM
87firebird's Avatar
I have measured it and I have drawn pictures and found out the best way that I would want to do it, but I wanted to see if anybody had something different than what I had.
Old May 14, 2001 | 09:40 PM
Eric 91RS's Avatar
Car: 92 Chevy 1500
Engine: 350 TBI
Transmission: TH-700R4
Building a box is not hard. All you need is a table saw and some particle board. I can't ever seem to get my measurments to come out right to get the correct air space, and still use the T-top bag. I would also like to see what others have come up with.
Old May 14, 2001 | 09:47 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
audio ok has boxes on ebay for 70 bux.
how cheap can you build one?
Old May 15, 2001 | 07:54 AM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by bubbz89:
</font>
5/8" Particle board = $10
1 bottle of glue = $4
charcoal carpet = $8
Watching it blow apart after you put a pair of Rockford HX2's in = Priceless.
Those boxes are cheaply made boxes.
The IROC Homepage
Old May 15, 2001 | 10:04 AM
Steve89GTA's Avatar
Use MTM wood
Old May 15, 2001 | 10:19 AM
Stoopalini's Avatar
I've always built boxes out of MDF (Medium Density Fiberboard). It is much stronger then particle board and doesn't fall apart.
I agree with building your own sub. It is a little cheaper and you can make it exactly the way you want it. Those $70 prefab boxes are junk! I personally feel that all pre-fab boxes are junk though.
My box holds a single JL 12", so I just built it to drop into the rear hole, right behind the gas tank.
I dunno how you could do it with 2 12's and still keep the T-Top bag???
Maybe you should consider another speaker that requires less enclosure volume?
Or, if the required volume is off by a small amount, you could polyfill the box to compensate for it.
Good luck,
Thomas.
Old May 15, 2001 | 08:56 PM
bubbz89's Avatar
Car: 1990 RS
they are made of mdf. i talked to the guy. but they are 5/8 opposed to 3/4. do you think its still not a good buy? i was going to get one. maybe i can get him to make it out of 3/4. i dunno.
Old May 15, 2001 | 09:03 PM
Jim85IROC's Avatar
The one in the picture is made out of particle board.
The IROC Homepage
Old May 15, 2001 | 09:07 PM
bubbz89's Avatar
Car: 1990 RS
well he said mdf
anyway its 86.36 shipped to memphis
what do you think
Old May 15, 2001 | 11:29 PM
Rallyssport's Avatar
All I did was basically worked my way up. It takes some thinkin but anyone could fig it out. just stop your top plate where the t-top bag hooks are. Dont forget your divider.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
