Amp Power Cable Firewall Entrance Location?
Old Jun 2, 2001 | 09:51 PM
Night Hawk's Avatar
In our cars, more specifically a 1988 L98 GTA, where's the best place to route a big 4 gauge power cable for an amp through the firewall. Is there any existing holes? It looks crowded but there is a clearing under where the throttle cable enters the firewall. Is this an ok area to drill a hole for the 4 gauge cable? Will it be easy to find once it's passed through the firewall? Any other suggestions?
Old Jun 2, 2001 | 10:30 PM
One Eyed Jack's Avatar
If your car is an automatic, use the clutch port. Otherwise theres a slot where the wires come in to the dash. Wire it through there.
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 3, 2001 | 05:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can always come in through the panel behind the kick panel too. There's a nice big flat area where you can drill a hole, and on the outside it will be behind the fender. Then you can run it into the engine bay behind the fender in the corner, and right up front to the battery. If you look on the passenger side, you can see where the stock antenna wire goes. You should be able to use a similar location for the power wire on the driver's side.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 9, 2001 | 04:25 PM
dude12387's Avatar
i have the same car, and routed mine through the existing hole under the steering colum
"When something breaks, it gives me an excuse to replace it with a performace part!"
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
JET Fanswitch
K+N's
JET chip
kenwood head unit, xplod amp, poineer 3 ways
weird rattling noises
dying 350
crappy paint
700R4 on its last leg
hood that won't open - sometimes
Old Jun 9, 2001 | 05:27 PM
Thirdgenfbody.com's Avatar
I shaved the antenna on my IROC - so im planning on running the cable out the hole the antenna cable came in, then up inside the fender, then inside the engine bay next to the A/C components. Simple, Easy, and out of the way.
Arthur-
1985 IROC Restoration In Progress
http://www.thirdgenfbody.com/projiroc/
Member # 98 of The Las Vegas F-Body Association
www.lvfbody.com
Old Jun 11, 2001 | 02:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My cable also runs thru that plugged-up hole by the steering column.
If you go under the dash by the driver's side, you can use existing studs as a guide to drill a new hole. Make sure to drill from the inside of the car to the engine bay! And don't drill thru your brake booster
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 19, 2001 | 03:55 PM
camaro6spd's Avatar
who ever did mine has it coming through the firewall somewhere near the passenger side lower corner.
Old Jun 19, 2001 | 07:05 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
My buddy and I ran 4 gauge in his 96 Avenger. He bought a big connector thru Jeg's that is used to relocate the battery in the trunk. We just used a hole saw on the end of my drill, I think 1 1/4", and mounted it thru the firewall, then sealed it with silicone. Then crimped 4 gauge terminals on each side to connect it. As you might know, 4 gauge doesn't bend real easy. This eliminated that prob. Plus the metal will NEVER cut thru the insulation on the wire.
Here's the link, it's about $15, but you can't go wrong by using it. Don't know if the link will work. If not, it's part #710-74145
http://www.jegs.com/images/products/71074145_small.gif
EDIT: Well, the pic worked. That's what it looks like. HEHE!!! www.jegs.com
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited June 19, 2001).]
Old Jun 19, 2001 | 09:39 PM
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
who ever did mine has it coming through the firewall somewhere near the passenger side lower corner.</font>
Thats most likly where i was describing previously.
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
ZsTransAm
Aug 11, 2015 07:30 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
