Q about side post terminals...
Old Jul 8, 2001 | 02:01 AM
pianiy's Avatar
I'm upgrading my system real soon and I'm going to put in a distribution block. I'll have to run either 4 or 8 guage wire from the battery but how to I actually spice it into the power wire with our side post terminals? Is there a device I can buy that lets me do this easily?
~Luke a.k.a. pianiy
'91 Firebird :: 305/TBI(L03)/700R4/T-tops ::
Mods: Catco high flow cat - B&M Shift kit - TA tail light conversion - K&N - MacEwen white faced guages
Stereo: Pioneer DEH-P8200R - Pioneer 6x9's - Kenwood 8" Tube
'87 Firebird :: LB8/700R4/220K :: R.I.P. ::
Firebird parts - Got an '80 Firebird for sale too
Moderator of tranny board over at TransAmGTA.com
Old Jul 8, 2001 | 04:15 AM
AmorgetRS's Avatar
Yes, there is a replacement piece of the screw that holds the battery cable on. What it does is basically a big screw for the battery, then another one "piggy backed" ontop of that.
They are very nice, wish I could desribe it better.
Old Jul 8, 2001 | 08:48 PM
Mike92RS's Avatar
http://www.mmxpress.com/accessories.html
under "Gold-Plated Battery Clamps:" the third one down is what you need. It replaces the screw holding the wire onto your battery, and has more threads sticking out, so you just bolt your power wire up to that. You can find the same thing (sans gold-plating) at a place like Auto Zone, or I've even seen ones by Rockford Fosgate at Best Buy.
- Mike
Old Jul 8, 2001 | 09:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Another option is to get a dual terminal battery. That's what I did for my IROC. I didn't feel that the little post thingie would look too good with 2 gauge wire coming off of it. By using the dual terminal battery, it allows you to keep the stock wiring intact and run all of your accessories off of the top terminal.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 9, 2001 | 12:34 AM
350iroc-z's Avatar
Jim
Just out of curiosty would be able to take a picture of how you have your 2 ga wired at the terminals. Just looking for ideas is all.
Ryan
www.350iroc-z.com
Old Jul 9, 2001 | 07:16 AM
Jim85IROC's Avatar
I'll try to snap a picture tonight if I remember. It's just your run of the mill overpriced gold plated terminal mount that has a hex screw on the top. I've got gold ring terminals on the wire that bolt down to this terminal. I'm in the process of switching over to chrome because I'm sick of the corroded gold, but so far all I have is the ground terminal.
The IROC Homepage
Old Jul 9, 2001 | 09:19 PM
Jza's Avatar
Jza
Jim: a little tip that can keep that gold looking good: smear some vasoline on the surfaces.
Old Jul 9, 2001 | 09:40 PM
Jim85IROC's Avatar
But then there's vaselene all over it!
I was never partial to the gold anyway. My engine is all polished aluminum, my amps are aluminum, my interior is grey, and there's those shiny gold terminals. I'm planning on going totally with chrome so that it will match the car better, plus they're lower maintance and I don't have to **** around with petrolium jelly all over my car.
The IROC Homepage
Old Jul 9, 2001 | 10:29 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
that ****'s all a waste of money,unless you want a proffessional look,I used 20ft of 4awg wire and copper ring terminals from lowes(home improvement center) total cost of $25. although the battery screw was already there from a previous install. all you need is bare metal conections,dielectric grease only where the electrical contact is,not all over your ****!
[This message has been edited by junkyarddog (edited July 09, 2001).]
Old Jul 10, 2001 | 06:57 AM
Jim85IROC's Avatar
Some of us just prefer our system not to look like a hack job. I also don't like the idea of sending 100+ amps of current through a cheap crimp-on ring terminal.
The IROC Homepage
Old Jul 11, 2001 | 08:24 AM
Jza's Avatar
Jza
Jeez, just on the terminal, not all over everything... And that actually goes for any battery terminal. If you go to the store and buy battery post washers, what you're actually getting is a felt washer saturated with petrolatum.
Of course, my lack of corrosion on the battery could also be due to it being a gel-filled sealed battery to begin with. I dunno, but it didn't hurt.
Well, okay it did turn the clear rubber protective covering to a not-so-clear amber color, but that thing just detracted from the look anyway.
And the terminal was twenty bucks. That hardly broke the bank..
See how it's got the 4 gauge on the main wire held on by a large hex screw (ring terminal sold seperately), and it's got two spots on the side that accept 8 gauge wire (you can see the wire for my MSD there, and the other side has the fogs).
[This message has been edited by Jza (edited July 11, 2001).]
Old Jul 11, 2001 | 10:42 AM
Jim85IROC's Avatar
That's the terminal style I used to have (still have on the +12 side) until I started moving over to the chrome stuff.
The IROC Homepage
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
BurlyChev
Aug 22, 2015 01:52 PM
1985chevydude
Aug 20, 2015 12:29 AM
Fronzizzle
Aug 17, 2015 02:52 PM
