anyone ever built a box that holds 2 12s, an amp, and fits only in the well...
and still has room under neath to store stuff (t-top bag, jumper cables. etc.) I know this may sound demanding, but that is what I am going to try and do. Anyone think that its not possible to do? I am having a hard time trying to think of ideas on how to build it, and I plan to start construction of it this weekk! this would be so much easier if I had tens!
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Bridgestone Potenza RE730 255/45ZR17 all around
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Pioneer head unit
Kenwood speakers
Now KYB equipped!!
Hey man, i'm going to build the same box your doing too. Anyway i came across this site from one of the older posts in this forum. It gives diagrams and measurments on making a box like you want.
I hope this helps you out man!
http://members.nbci.com/_XMCM/catdogg/speaker.htm
My opinion is if your gonna build a custom box that holds 2 12's and an am,and you still want space at the very bottom for stuff. You better off using 10's because your gonna get very little air space and those 12's will probably sound like crap.
I think it can be done. My subs only need 1 cu. ft. of air so space isn't really a problem. I think that If I put the twelves on the right side right next to each other, then I should have enough room to fit my amp next to them running parallel with the side of my car. The amps going to stick up about 3" so that I can put hinges on the box that holds the amp so that it can hinge towards the subs, opening a space to store stuff in! I know its hard to picture in your mind, but if I get it done, I'll post pics and dimensions.
[This message has been edited by matthew (edited September 06, 2001).]
It can be done, My friend and I built a box like the one you described in his 91 Z28 He has two 12 inch MTX subs and a 250 watt amp., Before you start to do it, know this- it is a pain in the *** and takes a while. There are about 14 different pieces to cut,and a few hard angles, but if you havent started the box yet,and you still want help, e mail me and i will walk you through the process. The finished product however, you will not be dissapointed with, It looks and sounds great and there is room for a t-top bag under it too. btw, neon lights look good on the top of the box.
MSTNG KLR- do you have any pics of the box? I would really like to see them. Time is one thing I do have. I will probably be working on it for about an hour each day, 5 days a week intil I get it done.
Ill get some pics of the finished product in and outside of the car as soon as i can, i dont think you will be dissapointed.
87' Camaro Z28
305 TPI
Stage 2 hypertech chip
Custom ram air w/K&N's
air foil
shift kit
aluminum driveshaft
posi
VST gas ryder gas shocks
3" flowmasters
custom muffler
87' Camaro Z28
305 TPI
air foil
shift kit
aluminum driveshaft
posi
3" flowmasters
custom muffler
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
db057
Aug 11, 2015 10:11 PM
