Battery Drain
Old Apr 13, 2002 | 05:29 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Battery Drain
It's getting warmer, and I'm thinking about my car. Soon I'll be home, and she'll be out of storage. Right now, I'm thinking about how to avoid blowing another battery. I've got my amp wired for 2ohms instead of the recommended 4ohms, and as expected, I've had a few problems. I'll have to replace my battery, and even though I just rebuilt my alternator, I'm thinking of upgrading. I've got a 1 farad cap, but am I doomed to buy a new battery every few months if I keep things wired wrong?
Old Apr 13, 2002 | 05:34 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
what do you have for wiring in your car? i've had two amps in both of my systems and have never gone through a battery. best bet, if you havent done it yet, is to upgrade the wiring between your battery, ground, and alternator to at least 4 ga. that will give you a big improvement. how is your cap wired?
Old Apr 15, 2002 | 10:50 AM
Hummer's Avatar
Car: 1986 Z28
I have 8 gauge running from battery to cap, and I wired the cap as per instructions that came with-(car's in storage, the exact wiring slips my mind) It's a Rockford cap...the battery, alternator and ground are all original-4 guage, I think.
Old Apr 15, 2002 | 11:02 AM
Matthew 4:19's Avatar
they way your amp is wired should not harm your battery, check your current draw while car is not running, should be less than .5 amps
Old Apr 19, 2002 | 01:18 AM
FiReBReTHa's Avatar
Optima yellow top deep cell battery. and never worry about it again,
Old Apr 20, 2002 | 02:43 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
unless you have something thats on even when the ignition's off, then you shouldnt have that bad of a drain. the alt is usually the problem, so on my old camaro i upgraded to a a 110 amp alt. never had a problem after that.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
