secondaries stuck open
Old Sep 18, 2002 | 07:17 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
my secondaries on my 600CFM edelbrock are stuck open........i think i see the reason why, but i cant figure out what to do about it since i have no idea what i am doing with carburetors
it seems like the rod that goes from the "cam" that opens the secondaries down to the lever that is "hit" when you go WOT is stuck on the "cam"
see i really have no idea wtf i am doing
please help
Old Sep 19, 2002 | 11:24 AM
ehhh i took a look at some pics of carbs and it seems like someone put the retainer on wrong...........
when should the secondaries open? at WOT?
cuz with the throttle completely closed they are propped open
if i open the throttle, WOT also, they stay in that one spot and do not move at all....................
i'm new with carbs, but common sense tells me this isnt correct...................
what should the secondaries do when i pull the throttle wide open?
car isnt running yet, but will be soon..............
Old Sep 19, 2002 | 11:34 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You got this carb used, right???!!!
Some one had the top off the carb and mucked up the linkage when they put it back together.
Lokk for a pic of a Edelbrock carb that shows the linkage
and fix yours.
You'll figure it out.......
Old Sep 19, 2002 | 11:39 AM
and fix yours.
well i bought the car used with the carb, i started it a few times before i began the project, and it idled good.....so i dont understand what the hell is going on here................but, yes it looks like the linkage is f'ed up
thanx man
Old Sep 19, 2002 | 08:41 PM
jfox55's Avatar
My secondaries stay locked open too!!! Oh yah, that's because the pedal is always to the floor.
Old Sep 19, 2002 | 09:14 PM
Xenodrgn's Avatar
lol at jfox
and yes, if it's a vac secondary carb, the secondaries will open more with less vacuum present in the system...
Mechanical secondaries rely on throttle position instead (for those high lift cams... )
Old Sep 19, 2002 | 11:50 PM
ok, my problem is that the secondaries are open AND THE CAR IS TURNED OFF WITH NO THROTTLE APPLIED
they are mechanical secondaries..........................i looked at the linkage and it appears ok.................also the plate in the airhorn is cocked open, whats up with that??
HELP PLEASE!!!!!!!!!!!!
Old Sep 20, 2002 | 12:02 AM
ok, disregard the airhorn plate being open, i looked at pic and its supposed to be like that
uhhhhhh, are the secondaries on the carbs angled? if so, maybe they are not open....................
whats the purposed of the plate thats inside the airhorn, what does it do?
what should the correct operation of the secondaries be? opened at WOT?
Old Sep 20, 2002 | 11:09 PM
well. i just figured out what the choke plate is LOL
as for the secondaries, everything on the outside of the carb appears to be correct and opertaing right.........my guess is that its something inside...............
Old Sep 22, 2002 | 07:11 PM
anybody?
Old Sep 23, 2002 | 05:04 PM
Xenodrgn's Avatar
*bump*
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
racereese
Oct 10, 2015 09:39 PM
ctoledo0834
Sep 18, 2015 04:16 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
