DR's a bunch of BS?
Old Oct 14, 2002 | 08:50 PM
fattie92's Avatar
DR's a bunch of BS?
ok, anyone that has DR rods, please take a caliper (ya know the tool that you use to see how thick something is).. and measure the tip of it. my car came with CH rods, and i bought DR rods... measured them today and the CH rods were 0.056 and the DR's were 0.057 !!!! its bigger and its supposed to make it richer???? i think i either got fake DR's , or something.... i dont know whats up with that..the only differance in them was the VERY VERY tip... my CH's had a flat tip, and the DR's had a point...this makes no sence at all. wouldnt the flat one be richer then the pointed one? it would be releasing more fuel sooner... can someone clear this all up for me?? ohh by the way i need something richer then DRs, any suggestions?
Old Oct 14, 2002 | 08:59 PM
fattie92's Avatar
ok i just took a closer look at them... the tip on the DR's is longer...but bigger diameter wise. the rest of the DR's taper above the tip is smaller diameter wise them the CH's. but wouldnt a shorter, smaller diameter rod be better?
Old Oct 15, 2002 | 12:22 PM
flyway190's Avatar
I'll trade you some CK's for those DR's.
Old Oct 15, 2002 | 12:31 PM
fattie92's Avatar
are the Ck's richer?
Old Oct 15, 2002 | 12:32 PM
flyway190's Avatar
The specs are here
Old Oct 15, 2002 | 12:42 PM
fattie92's Avatar
all of the mumbojumbo means nothing to me.. i dont know what all that stuff is saying!
Old Oct 15, 2002 | 01:42 PM
flyway190's Avatar
they are richer...maybe this'll help
Old Oct 15, 2002 | 04:32 PM
fattie92's Avatar
yeah i looked them up, they are .053 and the dr's are .057 ...ILL TRADE YOU!!! email me at fattie92@yahoo.com or my aol screen name is fattie92
Old Oct 15, 2002 | 04:45 PM
Marc 85Z28's Avatar
There's a LOT more to it than just the diameter of the power tip If you have any more of those overrated DR's, I've got some real nice CH's here that I'll trade ya!
Old Oct 15, 2002 | 04:55 PM
fattie92's Avatar
CH's blow, i have 2 sets. the come stock in our cars
Old Oct 15, 2002 | 05:08 PM
flyway190's Avatar
Here's an illustration to help explain that chart. A-G correspond to 0-degrees-90 degrees on that chart, respectively. The top rod is a CH, the bottom rod is a CK. Notice the longer power tip on the CK (designated L on the chart), and the CH has a short power tip (designated S).
Old Oct 15, 2002 | 05:24 PM
fattie92's Avatar
im likeing them CK's! lets hurry up and mail these to eachother already!
Old Oct 16, 2002 | 12:05 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The DR's are richer EVERYWHERE except for the very tip, than the CHs...
Old Oct 16, 2002 | 12:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I agree. DRs are very good overall rods for the stock to mildly modified.
When I put them in with the B hanger, I still had a stock LG4 with air cleaner and timing the only mods. The difference in response was amazing. When I did the mods in the sig, I didn't change anything (except idle speeds and choke pull-off adjustment), and they still get the job done. Now that the engine revs higher, the AV just opens up more, giving the extra fuel needed (I doubt they even got to the power tip with the stock LG4).
The DRs also worked great in the Edelbrock 1901 q-jet (from which they came) when I had that carb on the 396. The CKs slowed me down. When the Holley went on the 396, the Camaro got the DRs.
Old Oct 16, 2002 | 12:49 PM
fattie92's Avatar
but the CK's are richer then the DR's at WOT ?? thats all i really care about
Old Oct 18, 2002 | 08:53 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
I have the DR's, AX's and the smallest tips which are CC's which I have with my 406 in my 69 Malibu. I picked up 1.5mph going from the AX to the CC. I had to reset the secondary air valve today and it feels like it might be quicker even. I was running consistant 12.75 at 104 and now it is hitting 12.71 at 105.50. I just went ahead and put the AX's in the LG-4 83 T/A and I can't tell a difference just yet.
Don't know how many times I have had the hood open on the Malibu and I hear "Man get rid of the Quadra-junk and get a Holley" I have and it is slower. That car's combo works well with the Q-jet. Here are the specs on it.
This combo made 375 hp @5,000 rpm and 480 toruqe @3500rpm
on an engine dyno. It is probably closer to 390 hp or so since then. Breaking in and tuning a little better.
400 Small block bored .030
Stock balanced 400 cast crank and rods
#2467 TRW Forged pistons 11.00 to 1 Compression
Sportsman 2 heads out of the box with 64 cc's
XE 274 Comp Cams Flat Hydraulic-- Advanced 4 degrees
Performer RPM Q-jet intake.
Crane Energizer Rocker Arms.
Dynomax headers 1 5/8 Tubes
3" Flowmasters
350 Turbo Trans with a 2400 B&M converter
12 Bolt with 3.73 gears
BFG Drag Radials 275x50x15
3680 lbs of metal car.
1983 T/A LG-4
305 LG-4 stock engine with 67000 miles
5-speed with z-bar (no hydraulic clutch)
Positraction 3.73 gears
WS-6 equipped.
No power windows or locks.
Flowmaster muffler with no cat.
Factory Cowl Scoop that still works
E.T. 16.32 @ 89 mph.
Old Oct 18, 2002 | 09:06 PM
flyway190's Avatar
My car responds well to CC's also. I would really like to try some DX's, but I can't find anybody that has them, and supposedly they quit making them a long time ago.
Old Oct 20, 2002 | 09:03 PM
fattie92's Avatar
:lala: :lala: :lala: :lala: :hail: CK's !!!!!!!!!!!
the ck's and a k&N open element fixed my problem!!
Bubbajones_ya
Oct 25, 2015 08:01 PM
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Cleotiz
Sep 16, 2015 08:02 AM
