Edelbrock Carb proplems
Old Mar 18, 2003 | 04:22 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
If anyone knows what to do cause im about to give up. I have an edelbrock performer 600 cfm i have the adaptor hooked up all gaskets in place all lines pluged/connected proper jetting but when i try to start the car it cranks for a while then if i keep on trying it the carb will make a pop noise and shoot up alittle fire once i dont know waht to do..about to sell car please help i have a 86 z28
Old Mar 18, 2003 | 07:58 PM
batman63's Avatar
Is this a new carb or used & if used was if rebuilt?
Check your timing, ignition system & IMS screws.
Use some carb cleaner and spray around carb/intake manifold gasket to see if you have some vacuum leak.
Old Mar 18, 2003 | 09:51 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Have you pulled the distributor lately?
if not, then check the carb for flooding.
Old Mar 18, 2003 | 09:53 PM
The distributor is the problem i cant find the right fireing order. Ive tryed stock adn 180 degree i dont know what to do anymore
Old Mar 18, 2003 | 10:06 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Make sure it's wired and grounded right. Make sure you have a good module and the rotor is in place.
To start over and find TDC, pull the distributor again and pull the driverside valvecover and put the damper on TDC again & reinstall the distributor.
Make sure both valves on #1 cylinder are closed and nowhere near moving when you have the damper turned to TDC. Pulling the valvecover and watching the valves is the best way.
Old Mar 18, 2003 | 10:08 PM
see thats the pain in the *** i dont have money for new gaskets and when its at TDC te distb is on like number 6 *stock fireing order*
Old Mar 19, 2003 | 01:40 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
then find TDC and just pull the distributor then turn the rotor counter-clockwise and drip it back in and then keep doing this until it points at about #1 cylnder. i had this problem it singed off my brothers eyebrows because i had it 180 out and shot a fireball out my edelbrock. lol
Old Mar 19, 2003 | 12:40 PM
batman63's Avatar
I agree will all post's; check your dist. pull it out a see where your rotor is pointing to.
It should be pointing towards #1 cyl.
If not it may be 180 towards #6 cyl.
Mark your dampner with white out along with timing cover/mark to align TDC.
Old Mar 19, 2003 | 01:46 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive gone through this little dance a few times, people like to help (yea right) and get things mixed up. Turn the crank until the timing mark is in the center of the timing tab the rotor should be pointing to either NO.6 terminal or NO.1 terminal. Either is correct but if your poping still that tells us its 180* out and you need to point the rotor at no.1 instead or vise versa. No need to pull anything apart.
Just noticed batman said the same thing, oh well good advice should be repeated.
Old Mar 20, 2003 | 12:49 AM
batman63's Avatar
Last thing, check dist/plug wires,spark plug gap...
Old Mar 21, 2003 | 04:39 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Funny thing no one mentioned this.
Check the timing chain & gears. Right after I put on my Air gap and Edb. carb, the timing chain skipped due to age and the synthetic gear material. When this occurs, you can set the timing as many times as you like and the engine still won't run. Just an idea.
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Scorched1984
Sep 15, 2015 03:42 PM
WickedBowtie
Sep 11, 2015 11:24 PM
