tuning edelbrocks
Old Apr 22, 2003 | 09:39 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
tuning edelbrocks
i have an edelbrock 1406 600 CFM electric choke carb on my 305
i am pretty new to carbs...........
(also i should state that i do not have the instruction manual for this carb)
how do i use the 2 idle mixture screws to set my idle mixture?
also, i believe the car was running a little lean when i had it running last time, because i had a slight backfire when romping on the gas (or the timing could have been too far advanced)
whats the best way to select the proper jet size?
and exactly do the metering rods do?
Old Apr 23, 2003 | 12:20 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Dont change jets or rods. The standard setup for an edelcrock is 1 and a half turns out on each mixture screw for nearly every setup.
The rods get pulled down when there is high vacuum limiting the amount of fuel going through the jets--------> high vacuum, ------- > low vacuum.
At most you may need a spring set to adjust the flow under different vacuum loads.
Old Apr 23, 2003 | 10:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
http://edelbrock.com/automotive/eps_intro.html
Old Apr 23, 2003 | 04:05 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: tuning edelbrocks
One and a half turns out is an okay starting point for the idle fuel mix screws and one and a half turns in for the idle speed screw.
Lean when romping the gas could mean you need more accelerator pump shot.
Actual timed 1/4 mile runs is the best way to find the best jet sizes. Start with the secondary jets and look at your trap speed MPH to measure power gains/losses.
The metering rods/primary jet combos allow you some adjustments with your cruise A/F ratios.
For more info you can look here.
http://www.cardomain.com/member_page...217306&page=26
Old Apr 24, 2003 | 08:04 PM
so larger rods allow less gas, while thinner ones let in more?
how do i adjust the accelerator pump shot?
Old Apr 24, 2003 | 11:37 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The arm with 3 holes in the front of the carb. Move down to increase pump shot up to reduce. Yes you have the idea of the rods bigger allow less fuel also lighter springs keep the rods further down in the bore doing the same thing.
Old Apr 25, 2003 | 10:15 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
About halfway down this page:
explains how to adjust the pump-shot and has some pictures.
Old Apr 25, 2003 | 08:01 PM
ok thanx guys
need some more help
i am pretty sure i know the question to my answer i just want to make sure
while setting my timing, i noticed that my engine was idling very high (1500 RPM)
i failed to put 2+2 together, i shut off the engine and adjusted the idle mixture screws all the way in and then backed them out 1.5 turns
BIG MISTAKE
(i am thinking because my idle was set so high, the idle mixture was richened for that reason, so by resetting them, i leaned out the idle mixture way too much)
i then turned my key to shut the engine off because she was pinging pretty badly
engine would not shut off i had everything so screwed up
engine finally shut down about 5 seconds later
seems like it got hot enough to ignite the fuel that was still being sucked in (from my dumbass leaning the mixture out too much)
SO NOW I NEED TO:
set my idle speed screw wayyyyyyyyyyyyyyy down so the engine idles at about 800 RPMS then
that should work happily in unison with the mixture screws being set 1.5 turns out
Am i correct?
Old Apr 26, 2003 | 10:08 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea, you got the basic idea. I'd just check the choke also. Edlecrock set their chokes very tight and sometimes the linkage needs to be bent on the fast idle, the flap could be open but if fast idle is stuck....
Old Apr 26, 2003 | 04:45 PM
problem solved thanx for all the help so far
does this sound right?
i have the idle mixture screws 1.5 turns out and i am idling at 850 RPM
sound good?
Bubbajones_ya
Jul 6, 2024 08:32 PM
sreZ28
Oct 22, 2015 08:21 AM
S10K20
Oct 7, 2015 06:45 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
toronto formula
Sep 10, 2015 07:31 AM
