carb emissions
Old Aug 21, 2003 | 01:53 PM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
carb emissions
ive been thinkin about switching to a carb setup and i wanna know how it will effect my emissions. i really dont know anything about that for carbs. i live in maryland btw.
Old Aug 22, 2003 | 04:43 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
you wont pass..92 with carb is illegal.i have one. dont do it if you plan on passing emissions. i did it and now am dumping hundreds at a time trying to get it to pass. dont mean to come off like a jerk but it will save you money to not do the swap.
Old Aug 22, 2003 | 07:17 PM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
couldnt i just swap if after i do emissions and swap it back when its time to do them again
Old Aug 22, 2003 | 07:54 PM
xeroxed74's Avatar
buy an alcohol carb and run alcohol for your emissions test
Old Aug 23, 2003 | 04:19 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea you could do that, that would work. but no carb will pass on a 92 when its inspected not even an alcohol.In ny they give a sticker for your window after you pass. i just take my girlfriends car have it inspected and peel it off and put it on mine. then i have it inspected again.theres always a way around it you just gotta be tricky.
Old Aug 23, 2003 | 11:29 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
well at least here in NJ the vin number is on the inspection sticker...so if a cop ever notices i'd think thats a pretty hefty fine. so i dont know if thats a good idea
Old Aug 24, 2003 | 03:15 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea your right its a big fine.they use bar codes here so its not as easily noticed. i would just do as you planned and switch back to pass.
Old Aug 24, 2003 | 08:52 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey i passed NJ inspection with my carb and all u need to do is run the car lean and late. basiclly lean out the carb and retard the timming some and put some dry gas in and u will pass, trust me, the idiots even looked under my hood last yr and i passed.
Old Aug 24, 2003 | 09:35 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
was this on a 82 tho? 92's wont pass with carb unless, like you said they are realy careless.
Old Sep 6, 2003 | 02:17 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
'82s came with carbs, so they can pass with them. '92 had only TBI and TPI, so they cannot be legally passed with a carb.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
