Help!!! Ohh So Close!!!
Old Aug 26, 2003 | 01:35 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I got everything on my new 350 bolted in my car. Today we were gonna set on the carb and fire her for the first time. I have an Edelbrock Aluminum intake, Not sure which model, Its a square bore intake. I was planning on using the Q-Jet that was on the 350 when I got it, Its a 78' Q-Jet Mechanical choke, etc. Anyway. Now I cant finish my car because the carb wont bolt up to the square bore intake? Is there anything I can use for an adapter, Or should I just go out and buy a Holley?
Old Aug 26, 2003 | 02:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It would be cheaper to buy a new intake manifold that accepts the q-jet than it would be to go out and buy a new Holley.
You can use an adapter, but it will raise the height of the carb. That may cause air cleaner/hood clearance problems. Cheaper than either option in paragraph 1.
Old Aug 26, 2003 | 08:22 PM
SLOWFIVEOH's Avatar
Engine: 355
I went out and bought the adapter and got everything on tonight. The question is...Will this clear a stock IROC hood If I get a big enough drop base?
Old Aug 27, 2003 | 10:06 AM
five7kid's Avatar
You'll be the first to know, I guess.
Hard to say without knowing what intake manifold you have.
Old Aug 27, 2003 | 08:21 PM
SLOWFIVEOH's Avatar
Engine: 355
The carb itself is too high, Let along an air cleaner, guess I get to go buy my hood early!
Old Aug 27, 2003 | 09:42 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Wait...I did that same thing on my Roc and it fit fine....and i had the stock hood you must have goten one big *** adaptor got a pic?
Old Aug 28, 2003 | 06:42 AM
SlowMaro's Avatar
err you are gonna spend 500 bucks on a new hood, then get it painted, to avoid putting on a good manifold to drop the clearance? uhhhh......
Old Aug 28, 2003 | 11:33 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Kinda sounds like he had planned to get a hood anyway....
Old Aug 28, 2003 | 08:07 PM
SLOWFIVEOH's Avatar
Engine: 355
Actually I was planning on getting an aftermarket hood...As you can see in the signature. I also dont really think I need to go buy a new intake. One I have now is a very nice Edelbrock one and it was free! The adapter I got is a normal adapter, I think my problem with height is mainly just the intake has some height to it. My car is gettting all new exhaust done now so I cant test fit the hood, I drove it 20 mins over there with no hood and open headers. If the stock hood wont close I will mold this 2 inch scoop I got laying around here onto the hood from my parts car until I get the cash for a Ram-Air or Big-block hood!
Old Aug 28, 2003 | 11:49 PM
xeroxed74's Avatar
i dont think the big block or ram air hood will you give you the clearance you need. you might want to check around and see if there the same height as the stock hood. i know i had to use a daytona iroc hood to get the clearance i needed.
Old Aug 29, 2003 | 06:27 AM
SLOWFIVEOH's Avatar
Engine: 355
Not sure about the big block, But I do know the ram air gives about 2 inches worth over the air cleaner area. My friend has this hood on his car so I went and measured it. Anyone know of the big block hood gives the clearance? What about SS hood?
Old Sep 9, 2003 | 07:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What about a cowl induction hood? they make those from 2" to about 8" tall!!!
Old Sep 10, 2003 | 01:03 AM
Confuzed1's Avatar
Car: 83Z28 HO
Exactly what I was thinkin! :lala:
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
