fauling plugs,help
Old Dec 11, 2003 | 06:24 PM
chad89ta's Avatar
fauling plugs,help
i got a 650 dp with modded 355 if you pull the plugs out some will be black some will look new i dont understand it,please help,mods are 355ci rpm intake dart iron egale heads 215 cc comp cam ex274 pro billet disribator hei,msd 6al with blaster 2 coil i have replaced the power valve and put new plugs and wires cap rotor,it still does it
Old Dec 11, 2003 | 09:08 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Is there black smoke coming from the exhaust?
Old Dec 11, 2003 | 09:10 PM
chad89ta's Avatar
no smoke,its jeted 71 84,got my best ets with these jets
Old Dec 11, 2003 | 09:15 PM
chad89ta's Avatar
also has the 28 shooters
Old Dec 15, 2003 | 11:20 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
switch the plugs to different holes and see if the problem follows the plugs or is limited to certain cylinders. You might just have some bad plugs.
Old Dec 25, 2003 | 10:40 PM
chad89ta's Avatar
the plugs that looked new, i put them in the hole where the plug where black,now they are black,and the plugs that where black are now white after the switch
Old Dec 26, 2003 | 08:09 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Whats your timing at? Are you running a vacuum advance? You sure its not oil rather than fuel? How long does it take for them to this?
Old Dec 26, 2003 | 11:03 PM
chad89ta's Avatar
timing is at 38* with no vacuum advance,its not oil black charcoal like,it only takes about ten min to do this
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
